d15b motor swap problems
Old Dec 4, 2003 | 03:58 PM
b18cvtec's Avatar
Default d15b motor swap problems
swapped a d15b vtec in to a 90 crx si. with a obdo ecu non vtec. obdo distributor that will not mount properly. i can get the car to run rough but to keep it running we have to turn the distributor past the mounting brackets. anyone else had this problem??? or if any one has any solutions. because getting a obd1 ecu and distributor means we have to modify the wiring harness. please help.....
Old Dec 8, 2003 | 12:39 PM
Slammd Sol's Avatar
I beleive the JDM D15b is supposed to use the OBD1 P08 ecu..
Old Dec 8, 2003 | 05:44 PM
Jimmy's Avatar
Global Moderator
Default Re: (Slammd Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol &raquo;</TD></TR><TR><TD CLASS="quote">I beleive the JDM D15b is supposed to use the OBD1 P08 ecu..</TD></TR></TABLE>
Old Dec 8, 2003 | 06:54 PM
Kendall's Avatar
What's wrong with having to modify the harness? You can probably get all the info you need right here in Honda-Tech.
fin781
Jan 19, 2007 09:16 PM
89hatcher
Jun 5, 2006 02:01 AM
sloweredcivic
Feb 11, 2005 09:10 PM
fast90hatch
33
Nov 30, 2004 09:23 PM
justmotor13
Aug 1, 2003 09:54 AM
