brake cylinder boot
Old Dec 2, 2003 | 09:42 PM
david90's Avatar
Default brake cylinder boot
When my brake cylinder is pushed into the caliper, the boot seems distorded. Is there a way to fix this or do I have to buy a new caliper and it starts to leak?
Old Dec 3, 2003 | 05:14 AM
JimBlake's Avatar
Default Re: brake cylinder boot (david90)
That's a dust boot to keep the actual piston seal clean. It's supposed to spin/slide in it's groove, but it usually gets stuck. If you twisted the piston a bit when you pushed it in, the boot wrinkles. Of course on the rear it HAS to spin because you have to twist the pistons in.
Try to slide it around to straighten it, but be careful not to tear it... As long as your other brakes aren't apart, you can push the brake pedal a bit to push the piston out. Then straighten the boot, & push it back in straight.
Old Dec 3, 2003 | 05:33 PM
david90's Avatar
Won't my brake leaks if I take the piston out or is there another part that pushes on the piston?
Old Dec 4, 2003 | 03:43 AM
JimBlake's Avatar
Default Re: (david90)
Yes, if you keep pumping, you'll blow the piston all the way out. I didn't mean to pump the pedal that much. Just enough so you can work the dust boot around & straighten it.
Old Dec 7, 2003 | 09:08 PM
david90's Avatar
Why does my rear brake cylinder twist out instead of just pushes out like my front brake? Why is it like that?
Old Dec 8, 2003 | 05:21 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">Why does my rear brake cylinder twist out instead of just pushes out like my front brake? Why is it like that?</TD></TR></TABLE>That's the auto-adjust mechanism for the handbrake.
wazzabie
Jul 29, 2011 05:21 AM
CapYoda
11
Apr 23, 2005 03:08 PM
rasinhell
Mar 7, 2005 06:09 AM
Aber
Mar 12, 2004 02:51 PM
integra-modder
Jul 24, 2003 07:35 PM
