Need Specs for CTR Cam
Old Dec 2, 2003 | 06:22 PM
vtecb20coupe's Avatar
B A N N E D
Default Need Specs for CTR Cam
ok, need the specs for the ctr intake cam. 00+. thanks.
Old Dec 2, 2003 | 06:27 PM
Kendall's Avatar
Default Re: Need Specs for CTR Cam (vtecb20coupe)
Intake duration 278 on the mid lobe or 233 when measured at .050"
Exhaust duration 280 on the mid lobe or 224 when measured at .050"
Intake gross lift .449 on the mid lobe
Exhaust gross lift .417 on the mid lobe
Old Dec 2, 2003 | 08:48 PM
IN VTEC's Avatar
Default Re: Need Specs for CTR Cam (dc231)
Did you measure those out yourself?
I haven't gotten a chance to do it myself yet.
The closest I've come is using the specs from the Hybrid Honda site and degreeing them in to those specs.
https://honda-tech.com/zerothread?id=301837
-measured at 1mm
Old Dec 3, 2003 | 05:12 AM
B A N N E D
Default Re: Need Specs for CTR Cam (IN VTEC)
ok, so 233 when measured at .050 and 243 when measured at 1 mm lift? but we both agree that the total lift is 11.5 m? i need to know so i can have the valves adjusted correctly.
Old Dec 3, 2003 | 11:37 AM
B A N N E D
ok, i got the following: i know it's 18 degrees before tdc, 45 degrees after bdc, 11.5 mm lift, and 33 mm in diameter. but, what i need is to know the valve lash on the cam. if you know, let me know please!
Modified by vtecb20coupe at 2:58 PM 12/3/2003
Old Dec 3, 2003 | 03:15 PM
IN VTEC's Avatar
Valve lash is pretty standard for VTEC cams. .006"-.007" IN and .007"-.008" EX. Even most aftermarket VTEC cams have share the same valve lash clearance.
Old Dec 3, 2003 | 03:20 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Valve lash is pretty standard for VTEC cams. .006"-.007" IN and .007"-.008" EX. Even most aftermarket VTEC cams have share the same valve lash clearance.</TD></TR></TABLE>
He's right about the valve lash, and the specs I quoted earlier are from http://www.crower.com
Old Dec 4, 2003 | 05:12 AM
B A N N E D
yea, i relayed the info to him. thanks for all the help.
brandonschmidt
Dec 27, 2009 07:34 AM
Kr4nG
Nov 17, 2009 03:33 PM
SHG_EasyE
Jun 10, 2006 05:09 PM
TOFU.man
Apr 23, 2004 10:33 PM
blackANESE
Jun 27, 2002 02:22 PM
