Car is bogging when on Nitrous?
Old Dec 2, 2003 | 03:25 PM
whatVTEC's Avatar
Default Car is bogging when on Nitrous?
Ok first off the setup: B18b, built 150shot nitrous, Hondata S200.
Ok N/A the car runs fine, but when I used the nitrous the car hesitates around 6000
and then you can feel the nitrous hit again. Kinda weird. Bottle pressure was around 800
Old Dec 2, 2003 | 03:30 PM
Kendall's Avatar
It's possible that you have too much fuel going to the nitrous setup (assuming a wet kit). You really need to give some more specifics on how the nitrous is setup before anyone can give you a good answer.
Old Dec 2, 2003 | 07:53 PM
DC2Slow's Avatar
Default Re: Car is bogging when on Nitrous? (whatVTEC)
if bottle pressure was 800 thats way to low...i assume u mean 8000...and thats okey u want it around 10500-9500
Old Dec 2, 2003 | 07:54 PM
99blackcivicSi's Avatar
Default Re: Car is bogging when on Nitrous? (DC2Slow)
Is it an ignition miss or fuel? what does it feel like? what are you plugs telling you?
Old Dec 3, 2003 | 05:19 AM
crxste's Avatar
Default Re: Car is bogging when on Nitrous? (99blackcivicSi)
I thought bottel pressure was meant to be between 850 and 1050 psi not 8000!!
Old Dec 3, 2003 | 05:52 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
800 psi is way to low for that amount of spray...how do the plugs look?..try 1000-1100 psi..and make sure the plugs arent gapped too big.
Old Dec 3, 2003 | 06:52 AM
whatVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2Slow &raquo;</TD></TR><TR><TD CLASS="quote">if bottle pressure was 800 thats way to low...i assume u mean 8000...and thats okey u want it around 10500-9500</TD></TR></TABLE>
Are you joking?
Old Dec 3, 2003 | 06:54 AM
whatVTEC's Avatar
Default Re: (dc231)
Yeah it is a wet kit. It's always ran fine, this is the first time it has done it. Plugs are fine, I was only thinking it could have been low bottle pressure. I'm gonna refill this weekend and then see what happens.
Old Dec 3, 2003 | 07:17 AM
B16ASilverhonda's Avatar
Default Re: (whatVTEC)
It shouldnt be your bottle pressure, usually anywhere from 800-1200 is a pretty full bottle with alot of nitrous pressure, unless your running a scuba tank. Check your selniods and everything and make sure all wiring is still good and fuel and nitrous mixture is good
Old Dec 3, 2003 | 07:52 AM
torr's Avatar
Default Re: (B16ASilverhonda)
my friend had the same problem, it was his plugs. the plugs looked fine, but i wanted to swap them out anyways and that solved it. he had zex plugs and they worked for about 3mths and then they took a crap, so i replaced them with ngks.
Old Dec 3, 2003 | 11:47 AM
whatVTEC's Avatar
Default Re: (torr)
This just started happening when I switched plugs.
I went from Bkr7E to a R5671A-8.
What should I gap them at?
Old Dec 3, 2003 | 12:50 PM
myhatchrips's Avatar
which plugs are those? i say just stick with the bkr7en-11
Old Dec 3, 2003 | 01:52 PM
whatVTEC's Avatar
Default Re: (myhatchrips)
They were reccomended to me by Vernon @ ravermotorsports. Couple of other people have told me to use that plug also.
Old Dec 3, 2003 | 01:57 PM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16ASilverhonda &raquo;</TD></TR><TR><TD CLASS="quote">It shouldnt be your bottle pressure, usually anywhere from 800-1200 is a pretty full bottle with alot of nitrous pressure, unless your running a scuba tank. Check your selniods and everything and make sure all wiring is still good and fuel and nitrous mixture is good</TD></TR></TABLE>
theres a big difference between 800 and 1000 psi of pressure on a10lb bottle of nitrous....800 is too low if u are using a wet kit with a healthy shot especially with the 4 fogger direct port kits like what i use....
Old Dec 3, 2003 | 01:59 PM
DC2Slow's Avatar
my bad i meant between 900-1100 psi i havent looked at my n2o gauge in a while good luck
Old Dec 3, 2003 | 02:04 PM
SYD's Avatar
SYD
have u ever used the R5671A-7..they seem to work for me and alot of others i know...i have a friend who has sprayed a 180 shot with them with no problems.
Old Dec 3, 2003 | 03:40 PM
play with different gap settings.
Old Dec 3, 2003 | 04:26 PM
whatVTEC's Avatar
Default Re: (bruceleeroy)
no, haven't tried them, maybe I will.
Thanks
But 800 is too low than for what I'm running?
Direct port wet kit
Old Dec 4, 2003 | 05:31 AM
SYD's Avatar
SYD
IMO yes.. try 1000 psi..
Azn Kenny
Apr 21, 2006 02:35 PM
Rikter
Feb 6, 2005 10:13 PM
hondaeg5
Nov 28, 2002 12:09 AM
bulryder7
May 15, 2002 02:24 PM
