75 shot does not feel quick at all...
Old Apr 20, 2006 | 09:41 AM
Azn Kenny's Avatar
Default 75 shot does not feel quick at all...
I have a NOS single solenoid dry kit installed (along with colder plugs, B&M adj fpr, and timing pulled by 1 degree).
I'd say I'm a decent driver (15.6 @ 89 with only intake and exhaust LS) but I'm barely beating Preludes and CL-S's. Are dry kits really a waste of money? Should I convert it wet? My bottle pressure is around 800-900 psi (with a bottle heater).
Is there anything I can do to gain more power?
Thanks.
Old Apr 20, 2006 | 09:45 AM
b18sihatch's Avatar
Default Re: 75 shot does not feel quick at all... (LSntegra)
what are you running now? was that 15.6 without the Nitrous? what are you running now with the nitrous?
Old Apr 20, 2006 | 09:51 AM
Hybrid_Coupe's Avatar
check your jetting make sure its a 75 shot
Old Apr 20, 2006 | 09:54 AM
Azn Kenny's Avatar
Yeah 15.6 BEFORE n2o, haven't been track since the NOS, header, and tune.
The jet says .042 on it, I believe that is a 75 shot...
Old Apr 20, 2006 | 09:59 AM
b18sihatch's Avatar
Default Re: (LSntegra)
what would you say you run now if you had to guess?
Old Apr 20, 2006 | 10:45 AM
reallycooleg's Avatar
Default Re: (b18sihatch)
that bottle pressure is too low...should be 1000 psi
Old Apr 20, 2006 | 12:07 PM
Azn Kenny's Avatar
I'd say I'm mid-high 14's.
Old Apr 20, 2006 | 01:18 PM
Soccerking3000's Avatar
how are you adding more fuel?
Old Apr 20, 2006 | 01:20 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSntegra &raquo;</TD></TR><TR><TD CLASS="quote">Is there anything I can do to gain more power?
Rejet it for a 100 shot.
Old Apr 20, 2006 | 01:46 PM
Azn Kenny's Avatar
Well it's a dry kit so it just adds n2o.
I bumped up the fuel pressure to about 40 psi at idle (stock is 36-38 psi).
Old Apr 20, 2006 | 01:56 PM
you arent getting anywhere because its running lean as hell, get a wet kit and it will make a world of a difference...
Old Apr 20, 2006 | 02:01 PM
Azn Kenny's Avatar
That looks like my solution right there, thanks.
Old Apr 20, 2006 | 02:16 PM
hit up phasechangeracing they can get you a wet conversion kit and makes things really simple to convert
Old Apr 20, 2006 | 02:28 PM
s2kdre's Avatar
Default Re: (Soccerking3000)
1200 psi, thats where its the best at. i got a jdm r motor and i have a 70 shot single fogger wet kit on my car, and i have 12 degrees timing with 50 psi of fuel, i went from 98 mph to 110 in the 1/4 mile, so i think ur motor can do better than that, an ls with a 75 shot wet kit should be trappin at 104mph or more
Old Apr 20, 2006 | 02:59 PM
Azn Kenny's Avatar
That's exactly what I'm thinking but it feels nowhere near that quick.
Old Apr 20, 2006 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSntegra &raquo;</TD></TR><TR><TD CLASS="quote">That's exactly what I'm thinking but it feels nowhere near that quick. </TD></TR></TABLE>
its cause its a dry kit...
Old Apr 20, 2006 | 03:35 PM
Azn Kenny's Avatar
So my next question: Where can I get a cheap dry--&gt;wet conversion?
Old Apr 20, 2006 | 04:06 PM
turbolshatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">hit up phasechangeracing they can get you a wet conversion kit and makes things really simple to convert</TD></TR></TABLE>
right there
Old Apr 20, 2006 | 04:23 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSntegra &raquo;</TD></TR><TR><TD CLASS="quote">Well it's a dry kit so it just adds n2o.
I bumped up the fuel pressure to about 40 psi at idle (stock is 36-38 psi).</TD></TR></TABLE>
Most dry kits I've seen run pig rich. (better safe than sorry) Bumping up the base pressure makes it even more rich.
Old Apr 20, 2006 | 04:40 PM
Azn Kenny's Avatar
So put the pressure back to stock???
Old Apr 20, 2006 | 04:55 PM
sc4dr's Avatar
You really need a wideband to gauge your setup. A dry kit is fine if tuned correctly. AEM's are on sale for like $240 on Ebay
Old Apr 20, 2006 | 04:57 PM
Default Re: (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">Most dry kits I've seen run pig rich. (better safe than sorry) Bumping up the base pressure makes it even more rich. </TD></TR></TABLE>
he hasnt it done anything to make it rich though, his dry kit isnt like a zex with raising the fuel pressure, it would be best to upgrade to a wet kit regardless
Old Apr 20, 2006 | 08:55 PM
TheCheeseWedge's Avatar
well with my ls da with type r flywheel and msd coil on a 55 shot of zex i was running im guessing by all the cars i raced and beat around 14.3-14.5 area. nitrous really doesnt feel all that crazy as people make it out to to feel
Old Apr 20, 2006 | 09:01 PM
b18sihatch's Avatar
Default Re: (TheCheeseWedge)
well that is exactly what i was thinking, i mean it is 75 shot, but you areonly going to be so quick, unless you have other supporting modifications, i mean if you are runing around 14.5 and you were running 15.6 that is a little over a second faster on 75 shot. not grant it, you prolly need some tweaking and tuning on your system to have it running perfectly but that will only get you so far. what kind of drivetrain mods do you have, like flywheel,clutch,tranny,ect good clutch will help you along in better 1/4 times, you know all this. supporting mods will help tho
Old Apr 20, 2006 | 09:51 PM
Azn Kenny's Avatar
Yeah good point guys, I'm currently on stock clutch and flywheel, and I guess I can't complain on spending $300 and gaining a second in the 1/4.
Thanks for the insight!
