h22 on 93 civic si vtec not kicking in
Old Sep 17, 2001 | 06:54 AM
DUALSTAGE's Avatar
New User
Default h22 on 93 civic si vtec not kicking in
pls. help dont no what to do
h22 on 93civic si w/ p28 ecu repropram for dohc engine
wiring ok no engine code and perfect idle....my vtec not kicking in
any help will do
thanks.
Old Sep 17, 2001 | 07:22 AM
92CivicSiR's Avatar
New User
Default Re: h22 on 93 civic si vtec not kicking in (DUALSTAGE)
Do you have the pressure solenoi hooked up? If all of the electrical is correct, then I would start looking through the mechanical side of things.
Old Sep 17, 2001 | 07:27 AM
DUALSTAGE's Avatar
New User
Default Re: h22 on 93 civic si vtec not kicking in (92CivicSiR)
yes! every thing is wired up rite
i dont know what to do next
Old Sep 18, 2001 | 08:37 AM
H23 Power's Avatar
oil pressure guage? check the pressure
and check the vtec solenoid...could be bad
Old Sep 18, 2001 | 08:42 AM
VTEC4GS's Avatar
Default Re: h22 on 93 civic si vtec not kicking in (01GSR)
start diagnosing with voltmeter to see if it comes on from ECU end when driving. If not do check diagnostics, i.e. coolant temp, oil pressure, TPS @ WOT, speed sensor input, etc. IF ecu is fine, check for oil pressure at solenoid. before that jsut give solenoid +12v to hear it click.
Greg
Old Sep 21, 2001 | 07:42 AM
DUALSTAGE's Avatar
New User
Default Re: h22 on 93 civic si vtec not kicking in (vtec4gs)
i just change the oil sending unit still no vtec......Q: i unplug the vtec solenoid with the car running didn't throw any code(grey plug) is der something wrong w/ dat
sevenfc
36
Dec 28, 2022 05:01 AM
SiR Inspired ED7
Aug 26, 2022 01:33 PM
worx
Oct 18, 2009 08:52 AM
crowder13
Mar 11, 2007 09:53 PM
joshb3480
Oct 5, 2006 06:57 PM
