Good rebuild kit for sohc motor?
i want to rebuild the motor in my 93 ex, is there a good rebuild kit out there, what goes bad on these motors, what should i look for, what should i replace? Im going low budget, and im going to put puttin a turbo on with 10psi.
i would rebuid it with
-new bearings
-new rings
-have cylinders honed
-maybe lower compression pistons(much better for turbo)
-thicker headgasket(cometic or greddy brand)
-shot-peen the rods (relieves stress, stronger rods
-do a valve job on the head, maybe port/polish it mildly if your feeling ambitious
-change all the seals(front/rear crank seals, cam seals, etc)
-port intake if you want, would be good for turbo,
-bigger throttle body possibly
slap a turbo on that thing, set up a good fuel managment setup(uberdata or hondata=the best way, or a rising rate FPR if your feeling cheap)
-new bearings
-new rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC_WIT_IT »</TD></TR><TR><TD CLASS="quote">10 psi is kinda of pushing it. i'd go with the minimum of 5-7psi. but if you are sleeving it then 10 would be cool</TD></TR></TABLE>
You do not need sleeves to run 10 psi. If anything, worry about the rods.
BLKCivicPorscheStyle*
Dec 4, 2004 09:06 AM
