Wideband or EGT>?
As far as I know, An EGT deals some with helping your a/f ratio calibrations, but it's timing that really affects EGT's. I'd just stick w/ your wideband.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">I boutgh a plx wideband you guys think I need an egt, or is not needed?
Thanks for your opinions!!!</TD></TR></TABLE>
Not completely necessary but it won't hurt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">Whats is the EGT for? What can you tune from that?</TD></TR></TABLE>
EGT is just for exhaust gas temp. It basically good in conjunction with a wideband for ignition timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
EGT is just for exhaust gas temp. It basically good in conjunction with a wideband for ignition timing.</TD></TR></TABLE>
the temp displayed on an exhaust gas meter(pyrometer) represents how rich or lean your running your fuel by temperature, more or less. So if it shows a high tempuerature, say 1400-1600F your running way to lean, and if its showing 600-1000F your probably to rich. You can use this and a cheap narrow band sensor to do some excellent road tuning of fuel curves without a wideband if you know what your doing. I got my fuel just about dead on to 12.5:1 for my turbo set up just on road tuning, only made a few changes at high rpms when i ran a wideband on dyno. I suggest using a wideband and an exhaust gas meter, to help drivabilty and to build a low throttle map for your motor. Running a little extra fuel under low throttle helps keep turbo temperatures low which is always a bonus. It will also alert you to how hot your exhaust is getting and when you should give your car a break from high temperatures. If you dont have one, no biggie! good luck
