Anyone know anything about my euro-spec civic
Old Dec 1, 2003 | 08:43 AM
Blastek's Avatar
Default Anyone know anything about my euro-spec civic
I'm living in the UK and just bought a '95 civic 5dr, 1.6i LS 5spd. I was wondering if anyone had any horsepower/torque figures as well as curb weight. I'm always curious about the actual numbers that a car makes - no plans on racing or ricing
edit: Oh, and there is about a 1 inch play in both the accelerator and clutch pedals, would this be just a matter of tightening a few bolts or what?
obligatory picz:
Old Dec 1, 2003 | 08:45 AM
Spade's Avatar
Default Re: Anyone know anything about my euro-spec civic (Blastek)
You can pretty much base it off of the USDM LX.
Old Dec 1, 2003 | 09:09 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Anyone know anything about my euro-spec civic (Spade)
the play in the pedals is easy to fix.
For the throttle cable....
the throttle cable comes right over the intake manifold to the throttle body. Where it is bolted to the bracket, you will see 2 12mm nuts clamping it down. Loosen the nut on the left side and tighten the one on the right until there is minimal slack between the throttle body and the 2 nuts.
For the clutch...
underneath the dash, follow the clutch pedal arm up. You will see on the back side of it, a 14mm nut with a little "**** adjuster"....loosen the 14mm nut, and tighten that adjusting **** until there is minimal slack on the clutch pedal. Do not over tighten this because that will lead to premature clutch failure and slippage.
Old Dec 1, 2003 | 10:21 AM
built562's Avatar
Default Re: Anyone know anything about my euro-spec civic (Emerika)
thats a clean lokking car, i have never seen that before. the inside looks like an accord. i like the head lights
Old Dec 1, 2003 | 10:32 AM
93CX's Avatar
Default Re: Anyone know anything about my euro-spec civic (akumaracer)
interesting car
Old Dec 1, 2003 | 11:07 AM
Dr. EKology's Avatar
Wow, wood trim in a Civic! Never thought I would see that....
Old Dec 1, 2003 | 11:25 AM
emmo's Avatar
hey ive got the same car a '98 version with 1.5vtec engine, check out my pics on thre link below.
If you want more info on the engine you have go to http://www.hondarevolutions.com someone on the forum there will help you as its a uk model.
my pics
http://www.imagestation.com/album/?id=4289018699
Old Dec 1, 2003 | 11:34 AM
htcsi's Avatar
pseudo integra cluster? looks interesting
Old Dec 1, 2003 | 11:41 AM
HXvtec's Avatar
Default Re: (htcsi)
i like it
rattlecannedEF
Jul 4, 2009 04:52 AM
namewasdallas
Mar 10, 2008 07:19 AM
prelude_93vtec
Jun 3, 2007 08:23 AM
6shootahorsenamedtrigga
Oct 2, 2004 04:32 PM
NatrualAsp VTEC
Sep 17, 2003 05:19 AM
