broken wheel stud...need to replace!
Old Sep 16, 2001 | 06:06 PM
98hx99b18c's Avatar
Default broken wheel stud...need to replace!
I need to replace a stripped wheel stud, how do I go about doing this. It looks like I need a special tool, anyone who has done this any helpful hints, also do they make longer wheels studs for a 6gen civic? TIA
Old Sep 16, 2001 | 06:10 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: broken wheel stud...need to replace! (98hx99b18c)
Try using the Skunk2 extended wheel studs.
Old Sep 16, 2001 | 06:28 PM
paulzy's Avatar
Default Re: broken wheel stud...need to replace! (Blue-Civic-Hybrid)
you'll need an impact screwdriver to get the little screws that hold the rotor out. Use a size three head and a big fucken mallet.... You should be able to squeeze them out without taking anything else out.
Old Sep 16, 2001 | 09:48 PM
B18C-EJ1
Guest
Posts: n/a
You need to take of the brake rotor, then remove the wheel spindle. The studs are pressed into it.
http://www.nrg-racing.com had some Skunk2 extended studs last time I looked. I think they were $5/ea and they also had the aluminimum lugs too. Give them a shout Monday.
Old Sep 16, 2001 | 10:23 PM
paulzy's Avatar
Default Re: broken wheel stud...need to replace! (B18C-EJ1)
actually, you can just hammer them out of the spindle, them throw in the new ones and remember to tigten them down with the wheel....it's ghetto, but it works...
kvastek
Honda Civic (2001 - 2005)
Jan 11, 2022 05:29 AM
B bOy CrAyOn
May 1, 2007 12:42 PM
LudeyKrus
Jul 26, 2004 10:42 AM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
Tyson Ballou
15
Mar 1, 2002 06:31 AM
