new clutch
Old Nov 30, 2003 | 08:05 PM
dyases's Avatar
Default new clutch
I just got a new clutch installed friday and since then i've put ~200 miles on it. when i just feather the clutch out and let it roll into first on its own it almost "stutters", like kinda jumps the whole time till its rolling good. is that just normal for a new clutch or is something wrong?
Old Nov 30, 2003 | 08:09 PM
civic.com.hk's Avatar
Default Re: new clutch (dyases)
i want to know too because i am getting one soon.
Old Nov 30, 2003 | 08:10 PM
NoLimitMotorsport's Avatar
Default Re: new clutch (civic.com.hk)
what kind of clutch is it? Is it a Pucked clutch? Full face disc??
Old Nov 30, 2003 | 08:11 PM
Lucky_Smurf's Avatar
What type of clutch did you get? If it's a stronger aftermarket clutch then yes that's normal. Your getting a harder engagement and if you don't give it more gas to compensate for its "grabbing" effect you'll get a sutter like you did when you first learned to drive stick.
dyases's Avatar
Default Re: new clutch (Little Pepe)
Yeah, its a little stronger than stock but nothing too fancy. so nothing to worry about?
Old Nov 30, 2003 | 08:16 PM
No it's nothing to worry about. You just need to get used to driving with it. Try giving it a little more gas at the start. The only thing you need to watch for is if your getting a burned clutch smell or some serious vibration while driving. The sticky or grabbing feeling during engagement it perfectly normal.
Old Nov 30, 2003 | 08:21 PM
dyases's Avatar
feels fine driving, been looking out for any smells and its been fine. only thing is it seems kinda loud when in neutral but not as loud as my old clutch that was cracked
Old Nov 30, 2003 | 08:23 PM
Loud huh, that's probably nothing to worry about either. I'm assuming you have a light fly wheel and pressure plate as well or did you just go clutch. Personnally I recommend changing or resurfacing everything when you change out the clutch. At least get the flywheel and pressure plate inspected by a reputable shop. Sounds like your fine though.
Old Nov 30, 2003 | 09:25 PM
MissLady's Avatar
When I first got my puck/fly wheel it did that also. it eases up after a while, but you will always have a little stuttering effect if u don't grab right away.
altoid04
15
Nov 18, 2009 04:10 PM
jdmkha
Jun 25, 2009 09:46 AM
chueflee
Jun 1, 2007 10:19 AM
Loveless
Aug 4, 2003 12:19 AM
Accord_Munch
Dec 17, 2001 12:33 PM
