Crank pully TDC? Same as timing belt drive pully TDC?
Old Nov 30, 2003 | 09:41 AM
Civiclx's Avatar
Default Crank pully TDC? Same as timing belt drive pully TDC?
if the crank pully is at tdc, isnt the timing belt drive pully also at tdc since there is a "key" that keeps them moving together?
Old Nov 30, 2003 | 09:56 AM
Civiclx's Avatar
Default Re: Crank pully TDC? Same as timing belt drive pully TDC? (Civiclx)
cmon guys
Old Nov 30, 2003 | 10:14 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">if the crank pully is at tdc, isnt the timing belt drive pully also at tdc since there is a "key" that keeps them moving together?</TD></TR></TABLE>
I suppose you could look at it that way. What are you trying to do?
Old Nov 30, 2003 | 10:19 AM
Civiclx's Avatar
Default Re: Crank pully TDC? Same as timing belt drive pully TDC? (Chiovnidca)
i am trying to put on a timing belt
Old Nov 30, 2003 | 10:21 AM
Civiclx's Avatar
to put it on, both the camshaft gear and the crank pully and the timing belt drive pully have to be at tdc for it to time right, i was just wondering because it says to set the timing belt drive pully to tdc then put on the lower cover (d16y8) and put on the crank pully and set THAT to tdc also, well i was just wondering wouldnt it be the same position as the timing belt drive pully since they attach by way of a little metal "key" so technically they should be the same right?
Old Nov 30, 2003 | 11:31 AM
Evs-One's Avatar
Solbros Owns Me
yes.
The way I do timing belts is this........
put the timing belt over all pulleys, gears, etc.....
put bottom cover on. Pull belt off of the cam gears, line up crank pully at TDC on cover, line up cams at TDC, and then slide belt over.
This way, you can remove the belt from the cams without even touching anything on the bottom 1/2. Line upo the TDC mark on the crank pulley and that's good
Old Nov 30, 2003 | 11:39 AM
TeamNextGenChris's Avatar
yes,the white mark on the crank pulley,when lined up with the marker on the timing belt cover is the same as the indented line on the crank cog being lined up with the pointer on the block.i always use the line on the cog and block to line it up when doing a timing belt,though.
chris
Old Nov 30, 2003 | 01:23 PM
chad's Avatar
Moderator
Default Re: Crank pully TDC? Same as timing belt drive pully TDC? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">yes,the white mark on the crank pulley,when lined up with the marker on the timing belt cover is the same as the indented line on the crank cog being lined up with the pointer on the block.i always use the line on the cog and block to line it up when doing a timing belt,though.
chris</TD></TR></TABLE>
chris what are you talking about...you've never installed a timing belt!!
Old Nov 30, 2003 | 01:31 PM
KillerWabbit's Avatar
You really sound like you should get a Helms manual to walk you through this one. Replacing your timing belt isn't something you should tackle if you don't really know what you're doing.
Try a search and see if you can find some links to Helms manuals in PDF.
Old Nov 30, 2003 | 01:52 PM
Default Re: Crank pully TDC? Same as timing belt drive pully TDC? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
chris what are you talking about...you've never installed a timing belt!! </TD></TR></TABLE>
okay,you got me-i just run 'em until they blow up....like somebody else i know
chris
4dr_Noob
Nov 2, 2011 09:02 AM
ThA IntegrA HI
Dec 17, 2009 06:37 PM
Bob_760
Jan 30, 2008 02:48 PM
f150harleytruck7
Feb 13, 2006 12:04 PM
