What o2 should I get?
Old Nov 29, 2003 | 11:06 AM
Se-rv-Tak's Avatar
Default What o2 should I get?
Right now I have a univeral O2 sensor on my DX... it is wired up to my existing wiring harness... when I get an o2 sensor, which should I get if im going CRVtec?
Old Nov 29, 2003 | 12:11 PM
VTECVillain's Avatar
Default Re: What o2 should I get? (Soon2B18Boost)
Most OBD1 and newer Honda/Acura ECU's run a standard 4 wire O2 sensor, of course there are some exceptions: VX, CX, OBB0 1 wire, etc. Chances are that the ECU you will be using will require a 4 wire O2 which you can use from near any Honda/Acura or even an aftermarket one of that type. Neither the OBD style nor the primary/secondary of the sensor affect which one you can use, only the type (4 wire, 1 wire, etc.) to match what the ECU looks for.
Old Nov 29, 2003 | 12:27 PM
Se-rv-Tak's Avatar
Default Re: What o2 should I get? (VTECVillain)
ok. so replace my stock DX obd2 o2 sensor with a b16 obd1 o2 sensor?
Old Nov 29, 2003 | 12:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">ok. so replace my stock DX obd2 o2 sensor with a b16 obd1 o2 sensor?</TD></TR></TABLE>
It shouldn't be necesarry to switch since they should both be 4 wire O2's, either one will work.
Old Nov 29, 2003 | 12:35 PM
Se-rv-Tak's Avatar
oh ok cool deal. thanx.
Old Nov 29, 2003 | 02:38 PM
eyeamvic's Avatar
I don't think the dx is a 4 wire o2. Aren't the 4 wire o2's only on the VTEC equipped engines? You're gonna need the 4 wire o2 though for sure.
Old Nov 29, 2003 | 03:41 PM
Default Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">I don't think the dx is a 4 wire o2. Aren't the 4 wire o2's only on the VTEC equipped engines? You're gonna need the 4 wire o2 though for sure.</TD></TR></TABLE>
The DX uses a 4 wire O2. Basically from 92-95 Civic's, the only O2's that weren't 4 wire were the VX and CX. The 96-00 Civic's all had 4 wire O2's except the HX. Most OBD0 all use single wire O2's.
elchapin
Apr 2, 2008 09:38 AM
davidcrx89
Mar 22, 2005 04:43 PM
ProJectCvic
Jul 24, 2003 07:48 AM
