spark plug gap with msd
I always thought the goal was to get away with as big of a gap as you can w/out missing under boost. That way you can have the best idle and low end as possible. I found that w/my BTM, coil, wires, ect. I needed .03"-.032"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94dxt »</TD></TR><TR><TD CLASS="quote">I always thought the goal was to get away with as big of a gap as you can w/out missing under boost. </TD></TR></TABLE>
ya thats what i meant
keep gapping it down until it stops missfiring and also have a good spark on the low end at the same time.
i feel a little hesitation like when i'm at higher rpm. i never felt it before i put the msd on. it could be a misfire, but it feels like a little hesitation. i just tried it out last night for the first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb »</TD></TR><TR><TD CLASS="quote">i have mine at .030 right now, should i try to go down?</TD></TR></TABLE>
If it's running good then no need to gap it down. Only gap the plugs down some more if it's miss firing.
