A/C took a dump... and it's empty of freon or whatever you call it...
Old Sep 15, 2001 | 05:57 PM
GSRwBOOST's Avatar
Default A/C took a dump... and it's empty of freon or whatever you call it...
Just wanted to whine a little..
The neighbor helped me narrow it down to a leak, it's empty! I don't know when it drained out, but damn... what a pain to find the leak! then get the correct line to replace it!!!
modified cars are hell!
Old Sep 15, 2001 | 06:55 PM
FAST94GSR's Avatar
New User
Default Re: A/C took a dump... and it's empty of freon or whatever you call it... (GSRwBOOST)
did it crack a line from the heat of your turbo? maybe you should wrap them with something??
Old Sep 15, 2001 | 07:25 PM
GSRwBOOST's Avatar
Default Re: A/C took a dump... and it's empty of freon or whatever you call it... (FAST94GSR)
thats possible.. i havn't filled it with the dye/leak test kit you can get for A/C lines.. I'll post what i find out.
Old Sep 15, 2001 | 08:21 PM
yaksplat's Avatar
i had that happen
i just got a can of the leak stop and another can of the R134a
works as good as new now
you might need some more oil too
but i believe there's oil in the leak stop, so make sure you read the can
Old Sep 15, 2001 | 10:19 PM
GSRwBOOST's Avatar
Default Re: A/C took a dump... and it's empty of freon or whatever you call it... (yaksplat)
thanks for the suggestions...
D16SohcVtec
Jun 1, 2009 12:51 PM
ericschimmel
Jul 25, 2007 03:13 PM
Sketch_hs
Dec 22, 2005 01:44 AM
AndrewD
Feb 18, 2005 01:12 PM
wrXtian
Aug 30, 2002 06:50 AM
