A/C took a dump... and it's empty of freon or whatever you call it...
Just wanted to whine a little..
The neighbor helped me narrow it down to a leak, it's empty! I don't know when it drained out, but damn... what a pain to find the leak! then get the correct line to replace it!!! modified cars are hell! http://images.zeroforum.com/smile/emwink.gif |
Re: A/C took a dump... and it's empty of freon or whatever you call it... (GSRwBOOST)
did it crack a line from the heat of your turbo? maybe you should wrap them with something??
Re: A/C took a dump... and it's empty of freon or whatever you call it... (FAST94GSR)
did it crack a line from the heat of your turbo? maybe you should wrap them with something?? |
i had that happen
i just got a can of the leak stop and another can of the R134a works as good as new now you might need some more oil too but i believe there's oil in the leak stop, so make sure you read the can |
Re: A/C took a dump... and it's empty of freon or whatever you call it... (yaksplat)
thanks for the suggestions...
