How do you seal a leaking AN fitting?
Old Jun 1, 2009 | 09:31 AM
D16SohcVtec's Avatar
Default How do you seal a leaking AN fitting?
I'm using a 90 degree 12 AN fitting as part of my oil return. The fitting is leaking a small puddle of oil. I've made the fitting as tight as I could make it, and it's still leaking. What can I do to fix that? I was thinking about just JB welding it. But any other suggestions would be appreciated. Thanks
It's leaking where I drew the arrow.
Old Jun 1, 2009 | 11:12 AM
omgwtfbbq's Avatar
Default Re: How do you seal a leaking AN fitting?
you may have over tightened it and cracked it. Don't feel bad, I've done it a few times. You're gonna have to replace the fitting.
Old Jun 1, 2009 | 11:34 AM
Are they really that fragile? Those fittings aren't cheap either.
Old Jun 1, 2009 | 11:52 AM
dpetro1's Avatar
they are soft aluminum so it might become deformed when over-tightened causing it to leak. also its possible that using mismatched fittings could cause a leak but not very probable
Old Jun 1, 2009 | 12:26 PM
m R g S r's Avatar
It doesn't seal there, it seals when you tighten it to the bung on the tapered conical area. If you understand where I am talking about. So you might need a new bung and fitting, unless the bung is steel (which it most likely is because most honda pans are steel) in which case the aluminum fitting probably got messed up and the bung is probably fine.
Old Jun 1, 2009 | 12:51 PM
I learned something new here, I just JB welded it. Let's hope it fixes the leak.
carlos8
Apr 13, 2012 04:39 PM
shortstopNE
Apr 4, 2009 09:39 AM
ericschimmel
Jul 25, 2007 03:13 PM
Sketch_hs
Dec 22, 2005 01:44 AM
GSRwBOOST
Sep 15, 2001 10:19 PM
