limp mode
Old Nov 27, 2003 | 11:54 AM
PhatHatch89's Avatar
Default limp mode
my car is in limp mode and is throwing code 16 which is for the injectors. my car seems to be running really hot, will that cause it to go into limp mode? any help would be good. thanks
Old Nov 27, 2003 | 11:57 AM
onePOINTsix's Avatar
Default Re: limp mode (PhatHatch89)
limp mode on a nonOBD car?!? wow i didnt even think the ECU would do that, one of you injectors might be soo gone it's not even firing, causing it to seen like a limp mode
Old Nov 27, 2003 | 12:00 PM
Default Re: limp mode (Sideout)
how will i find out if one of the injectors is bad. they came with the new engine.
Old Nov 27, 2003 | 12:01 PM
also the engine is a single cam vtec which is obd1 and i am running the p28 ecu
Old Nov 27, 2003 | 12:03 PM
91civicEX's Avatar
whats ur injector setup? obd0 with an injector box or obd1 without a resistor
Old Nov 27, 2003 | 12:28 PM
dohcnotec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">limp mode on a nonOBD car?!? wow i didnt even think the ECU would do that, one of you injectors might be soo gone it's not even firing, causing it to seen like a limp mode</TD></TR></TABLE>
Dude, what are you talking about??? This is the second bonk post in a row I've seen from you... stop posting nonsense Of course obd0 ecu's have limp mode. Your injectors or wiring need to be checked. You are probably overheating from massive detonation caused by a lack of fuel. I suggest you go see your mechanic immediately or start saving for a swap/replacement motor...
Old Nov 27, 2003 | 12:33 PM
dohcnotec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">limp mode on a nonOBD car?!? wow i didnt even think the ECU would do that, </TD></TR></TABLE>
I wish you guys would stop saying nonOBD. That is WRONG. The car is OBD0. All 84+ PGMFI Hondas (at least Civics) have ON BOARD DIAGNOSTICS (OBD). The 0 is just a version number (like v0.2, etc).
Old Nov 27, 2003 | 12:46 PM
kid-honda's Avatar
Its called OBD or OBD 0
Old Nov 27, 2003 | 06:57 PM
Giuseppe's Avatar
Default Re: limp mode (dohcnotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcnotec &raquo;</TD></TR><TR><TD CLASS="quote">
I wish you guys would stop saying nonOBD. That is WRONG. The car is OBD0. All 84+ PGMFI Hondas (at least Civics) have ON BOARD DIAGNOSTICS (OBD). The 0 is just a version number (like v0.2, etc). </TD></TR></TABLE>
'officially' there isnt an OBD designation for 88-91 hondas.
Honda came out with OBD1 and for simplicity sake, people attached the
OBDO, nonOBD, preOBD designations to indicate that its 88-91 ECU/car.
any hardcore ECU gurus out here to back this up.
Old Nov 29, 2003 | 07:35 PM
Default Re: limp mode (Giuseppe)
i am running obd1 injectors w/o resistor box. currently it seems to be fixed. no check engine light. the car is running great. as soon as i took out the thermostat the car seemed to run fine. i just need to go get a new one. the car doesnt seem to run as hot now with it removed. dont knowits weird. anyways as for now i guess im good. i will let everyone know as the wek progresses. thanks
EKHWhat
Feb 2, 2007 05:38 PM
dkrex001
Nov 28, 2006 04:47 PM
4thgenhtch
Jan 31, 2006 12:44 PM
prelude9999
Oct 18, 2004 11:49 AM
hypa
May 20, 2003 03:48 AM
