Racing Camshafts
YES, i had a gude cam and ecu and some other bolt-ons on my d16 back in the day. It was running 15.0's at like 93-95mph on street tires all day with shitty 60' ft times. It ran really strong before i decided to go b-series. It also had a lumpy-*** idle which made it sound pretty cool too
Delta Cams is the way to go!! they only charge $85 for a regrind and have 2 different choices, a 260 and a 272, more info on A6 cams here:
https://honda-tech.com/zerothread?id=427814
What are your plans for the car?
Many "racing" cams require upgraded valvesprings, and sometime other internals. Also, since it is a SOHC non-VTEC engine, your fuel mileage and low-end power will suffer and your idle will not be smooth.
If you daily drive your car, I would suggest going with a slightly more aggressive street or street/strip type cam. A full race cam wouldn't be a good idea.
The cam list that Sideout linked to is very informative. You may also want to try a search.
