IGNITION RETARD QUESTION
I am wondering if its safe to retard my ignition timing when using an MSD 6AL. I do not have MSD BTM, but will be retarding the distributor mechanically. I cant see how this wold cause a problem but thought i'd check...
thanks in advance
thanks in advance
at the moment i have stock ignition but slightly retarded. I am wondering if I put an MSD 6AL box onto the distributor can i still leave it retarded??? Surely someone out there must of done this....
Its only temporary till i can afford the BTM add on for this unit....
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko »</TD></TR><TR><TD CLASS="quote">
thanks in advance</TD></TR></TABLE>
Don't you mean thanks in retard??
Of course you can set your timing however you want, regardless of where your spark comes from... Won't be a problem whatsoever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">how much are you boosting?
, no prob, though.
