Turbo Questions
Old Nov 25, 2003 | 10:15 PM
IntegraBoy04's Avatar
Default Turbo Questions
I want to go turbo here in the next year, and I was wondering if I should just boost the stock block, or be safe and build it first. If I build it, would pistons, rods, sleeves and cams be enough, or would I have to do more? Also, my goals are around 300-350hp. what kind of turbo would you guys recommend? Precision, Turbonetics, Garrett, Greddy? And what kind of intercooler? I don't want a kit, so please don't recommend it. This is all for a 99 ls, and help would be great. Thanks.
Old Nov 25, 2003 | 10:17 PM
redboost10's Avatar
Default Re: Turbo Questions (IntegraBoy04)
it all depends on your goals and money
Old Nov 25, 2003 | 10:18 PM
Default Re: Turbo Questions (tgh99si)
If money is not an issue. And I just stated my goals. I also want to hit 11s. Also, what size injectors do you recommend. And what size fuel pump?
Old Nov 25, 2003 | 10:20 PM
redboost10's Avatar
for the block if money is not an issue get sleeves, rods, low comp pistons, i think some guys have been in the 11s with a stock ls block, youll have to search
for the fuel rc 550cc injectors, walboro 255 intank pump
Old Nov 25, 2003 | 10:24 PM
redboost10's Avatar
https://honda-tech.com/zerothread?id=653254
heres a thread for you to get an idea
Old Nov 26, 2003 | 06:19 AM
Thanks. I will have about 7 grand to spend next summer. So that is about my limit. Plus I want to get a brake kit with that.
Old Nov 26, 2003 | 07:11 AM
RedTegLS's Avatar
$7000
You could easily hit 11's with that and have money left over. Just search the FI forum for all of your questions first.
Old Nov 26, 2003 | 08:30 PM
Default Re: Turbo Questions (RedTegLS)
Ok, thanks. But how much building should I do?
Old Nov 26, 2003 | 09:59 PM
Stein's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, thanks. But how much building should I do?</TD></TR></TABLE>
Set a horsepower goal that will get you into the 11's and build from there.
Old Nov 27, 2003 | 07:30 PM
Default Re: Turbo Questions (Stein)
Will around 350 get me in the 11s? And what kind of pistons, rods, sleeves would be good?
Old Nov 28, 2003 | 01:32 PM
Nobody can help me out?
Old Nov 28, 2003 | 02:15 PM
eG_6ix's Avatar
how about getting your block sleeved by benson, je pistons, crower or eagle rods, hondata, 550s, maybe a fullrace kit, or parts from and a few other misc items
Old Nov 28, 2003 | 03:29 PM
Default Re: Turbo Questions (eG_6ix)
Ok, thanks for the advice. What kind of turbo would be good? Precision, turbonetics, Garrett?
Old Nov 28, 2003 | 04:37 PM
RedTegLS's Avatar
If you want to make big power do a search on sc61 and you will get a ton of threads and opinions. I guess the spool later in teh rpm band but hang on when they do
Old Nov 28, 2003 | 04:58 PM
Thanks.
Old Nov 29, 2003 | 09:01 AM
What would be a better turbo? I don't really want that much power.
Old Nov 29, 2003 | 06:32 PM
Nobody?
Old Nov 29, 2003 | 07:36 PM
Ri5e's Avatar
350 WHP is cake on a stock sleeves with good tuning, that should net you high 11's on slicks with the right weight and with a good driver
T3/T4e would be more than enough or get a SC61 like what everyone else is doing
Old Nov 29, 2003 | 08:23 PM
Default Re: Turbo Questions (BG Boost)
What do you think it would take to hit 11s on street tires. And you are saying that I don't need to resleeve it? And doesn't the SC61 take a long time to spool up? I don't want to wait forever.
Old Nov 29, 2003 | 08:35 PM
eG_6ix's Avatar
well too much power at low rpms is going to make your tires cut loose alot easier, so i dont think alot of mid and high range power will be that big of a deal...you'll only have to deal with lag till about 4k or so and if i remember correctly the sc61 is usually up to full boost by 5.5k rpms
Old Nov 29, 2003 | 08:53 PM
Ok, thanks. So is the SC61 really worth the money, or should I just go with a T3/T4? And is the AEM EMS really worth the money, or should I just go with Hondata?
Old Nov 29, 2003 | 09:24 PM
rocket256's Avatar
hey bro. this is an idea. jsut go get a Rev Hard stage 2 kit with a hondata 2b and be happy all for about $3200-$3500. and have 300-30hp.
Old Nov 30, 2003 | 07:31 AM
Default Re: Turbo Questions (rocket256)
Thanks for the idea, but I don't really want a kit. For the reading I've been doing, I've figured I could get more power out of a custom setup.
Old Dec 1, 2003 | 06:44 AM
Anybody else?
Old Dec 1, 2003 | 06:52 AM
quikB18B's Avatar
You know my advice, start small learn and then go bigger. 11 second integras dont happen overnight . It takes alot of $, time, patience, experience....
My suggestion is go with a revhard kit, or a good custom kit, the sc61 is a badass turbo, but it's not for everyone. I would look into something smaller.
mando_eg2
Sep 3, 2013 08:12 AM
jrun666
Oct 15, 2011 06:43 PM
lsvtechatchy
May 14, 2010 05:52 PM
acurar
Feb 5, 2008 01:40 PM
Rah Rah
Oct 24, 2002 04:21 AM
