rust on rotors?
If you are referring to the areas where the brake pads do not make contact (i.e. Hub), remove your wheel and take a wire brush to it.
I finished it up by applying a coat of black high temp paint. No more rust for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 »</TD></TR><TR><TD CLASS="quote">Drive around the block a few times and use your brakes.</TD></TR></TABLE>
ha yea, did you look at them after your car has been sitting? they ususally look like that, drive around and the brake pads will clean it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">If you are referring to the areas where the brake pads do not make contact (i.e. Hub), remove your wheel and take a wire brush to it.
thats what i need to do...how did u mask off the area the pads touch?
</TD></TR></TABLE>thats what i need to do...how did u mask off the area the pads touch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it »</TD></TR><TR><TD CLASS="quote">
thats what i need to do...how did u mask off the area the pads touch?</TD></TR></TABLE>
some good ole masking tape
no joke
no joke
VTECAcuraGSR
Apr 4, 2006 10:55 AM
