chipped ecu's
Old Nov 24, 2003 | 05:50 PM
ekb18cCivic's Avatar
Default chipped ecu's
ok.. im putting a b18c in my car this spring.... im working it now.... its a 2001 and has 14k on it.. i need to buy an ecu.. i want to make it obd 1 alos ..i was looking into the skunk 2 one.. but someone told me to buy a chipped p28.. what exaclty is that.. what does it do.. i read alot of back threads but they only mention the name not what it does.. what is the diff between a reg p28 and a chpped one????
Old Nov 24, 2003 | 05:58 PM
Osoboosted's Avatar
a b18c doesnt fit in ur car.. only a K series.
Old Nov 24, 2003 | 06:03 PM
Default Re: (Osoboosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Osoboosted &raquo;</TD></TR><TR><TD CLASS="quote">a b18c doesnt fit in ur car.. only a K series.</TD></TR></TABLE>i take it your kidding.. well at least i hope you are .. i have a 98 civic
Old Nov 24, 2003 | 09:43 PM
Osoboosted's Avatar
Default Re: chipped ecu's (ekb18cCivic)
[QUOTE=ekb18cCivic its a 2001 and has 14k on it.. [/QUOTE]
see that .. when u said that ... looked like u were talking a bout ur car not ur engine...
Old Nov 25, 2003 | 02:42 PM
Default Re: chipped ecu's (Osoboosted)
see that .. when u said that ... looked like u were talking a bout ur car not ur engine... </TD></TR></TABLE>ooo my bad.. lol .. i guess noone wnts to help me
Old Nov 25, 2003 | 02:45 PM
infinatenexus's Avatar
Go with a hondata S-100.. chipped ECU's can lead to many problems, and bad gas mileage
Old Nov 25, 2003 | 02:54 PM
Default Re: (infinatenexus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus &raquo;</TD></TR><TR><TD CLASS="quote">Go with a hondata S-100.. chipped ECU's can lead to many problems, and bad gas mileage</TD></TR></TABLE> what do they run in prie and do i only need the ecu???
Old Nov 25, 2003 | 03:15 PM
Default Re: (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic &raquo;</TD></TR><TR><TD CLASS="quote"> what do they run in prie and do i only need the ecu???</TD></TR></TABLE>
I pait 75.00 for A p28, 245.00 for the S-100 and 50 to get it installed, and get a basic program.
Old Nov 25, 2003 | 03:20 PM
Ag-Eng's Avatar
What you need is a P72 ecu for your GSR engine.
UNLESS you're talking about an ITR engine, and in that case, a chipped P28 will work fine for you.
I like Hondata, but unless you're willing to pay for major dyno tuning time, there is no benefit to just buying the Hondata and a baseline chip.
If you're interested in more info or what I have available, PM me and we'll discuss it.
Old Nov 25, 2003 | 03:28 PM
Good ol' Screwtape's Avatar
Multi-paradigm
PM user "Fobtions" for chipped ECUs. His shiet owns. And he'll sell it cheap.
Old Nov 25, 2003 | 03:36 PM
lazy bum shaughn's Avatar
B18C is a JDM Integra Type R motor. Most people just forget to put the 1 at the end, which is a GSR motor. Which one are you getting?
Old Nov 27, 2003 | 09:31 AM
Default Re: chipped ecu's (lazy bum shaughn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazy bum shaughn &raquo;</TD></TR><TR><TD CLASS="quote">B18C is a JDM Integra Type R motor. Most people just forget to put the 1 at the end, which is a GSR motor. Which one are you getting?</TD></TR></TABLE>sorry im getting the b18c1
Old Nov 27, 2003 | 11:03 AM
95hatch's Avatar
thats funny because my motor is stamped b18c and i could of swore it was a jdm gsr.
Old Nov 27, 2003 | 11:06 AM
King Tut33's Avatar
Default Re: chipped ecu's (95hatch)
Yeah B18c can be ITR or GSR. As for the chipped P28. Most people choose to run it on swaps because they are fairly cheap and readily available. If you run one, I would recommend the Skunk2 program, VAFC, FPR, and dyno tuning so that it performs well.
Old Nov 27, 2003 | 11:18 AM
jeremyEG's Avatar
Default Re: chipped ecu's (King Tut33)
unless you are planning on changing the IM out for a skunk2 i would highly recomend NOT getting a chipped P28. you will have no way to activate the IAB and you will lose a good bit of midrange. if you go with the skunk mani you will be fine running a chipped ecu though.
just look for an obd-1 p72 if you dont want to change the IM. then you will have to buy a jumper harness to run it obd-1 also.
and if you do buy a chipped p28 and skunk mani. remeber that on a gsr the low end cam stops making power in the 4400 range. so you dont want a chip with a vtec x-over of much higher than that unless you have a vafc or fields vtec controller to lower it down to 4400.
Old Nov 29, 2003 | 10:42 PM
Ag-Eng's Avatar
Default Re: chipped ecu's (jeremyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremyEG &raquo;</TD></TR><TR><TD CLASS="quote">unless you are planning on changing the IM out for a skunk2 i would highly recomend NOT getting a chipped P28. you will have no way to activate the IAB and you will lose a good bit of midrange. if you go with the skunk mani you will be fine running a chipped ecu though.</TD></TR></TABLE>
Not true anymore. I have modified p28's to run the IAB with no problems.
Modified by Ag-Eng at 4:26 AM 12/3/2003
Old Dec 2, 2003 | 09:31 AM
1hotintegra's Avatar
Default Re: chipped ecu's (Ag-Eng)
i got a p28 for ya.. let me knwo
Old Dec 3, 2003 | 12:29 PM
iH8RICERZ's Avatar
Default Re: chipped ecu's (1hotintegra)
If you dont plan on switching out your stock intake manifold w/ a skunk2 or jg manifold, and if your motor isnt really modded, I dont recommend running a chipped p28 on a b18c1 (GSR). I would run a stock p72 obd1 ecu to run your secondaries in your stock intake manifold. If you run a chipped p28 on a basically stock motor, then you run the chances of actually losing horse-power. A chipped p28 (depending on the programs available) have advanced a/f curves, thus causing a more agressive power ban. If you dont have the cams/modifications to back up the fuel its dumping, your just going to run rich, and your car wont run as good as it would on a stock ecu. If you do plan on doing some hardcore mods, that need some hard core tuning, then I do recommend going with hondata. If you have any questions, feel free to PM me
thanks
Jason
97dc2ftw
23
Apr 11, 2011 11:10 PM
Red_ED8
Apr 6, 2006 02:26 PM
crashzerothree
Mar 6, 2006 03:17 PM
BLK99VTECR
Oct 1, 2003 05:01 PM
IS3Fifty
Apr 26, 2003 04:37 PM
