'98 Civic Type R - Blue Smoke
Old Nov 24, 2003 | 12:59 AM
r2ck_p's Avatar
Default '98 Civic Type R - Blue Smoke
Hi, I own a 1998 Civic Type R (EK9), it has 39,000 miles on the clock and seem to get blue smoke from the exhaust on gear change/pulling away from traffic lights. I believe this is burning oil, but why? Can anyone suggest any bits that need checking as its booked in to be looked at next week.
Has anyone else had this problem and if so how did you solve it?
Thanks,
Rick
Old Nov 24, 2003 | 07:38 AM
b18c-rex's Avatar
Default Re: '98 Civic Type R - Blue Smoke (r2ck_p)
oil..you prolly burning oil
Old Nov 24, 2003 | 08:06 AM
AL ASPIRATED's Avatar
im not sure where it can be from, but the worst it would be is a headgasket
Old Nov 24, 2003 | 08:59 AM
bogus_ek's Avatar
Default Re: (JDMTyPeRHaTcH)
i second the headgasket... might even just be that the headbolts aren't torqued on right...
Old Nov 24, 2003 | 10:21 PM
b18c-rex's Avatar
Default Re: (bogus)
valves seals...check your oil....lol...maybe a compression check
Old Nov 24, 2003 | 11:13 PM
r2ck_p's Avatar
Default Re: (b18c-rex)
Thanks guys for your help.
I will keep you posted hopefully it won't cost to much to repair.
Thanks,
Rik
Old Nov 25, 2003 | 12:02 AM
aeolus's Avatar
Default Re: (r2ck_p)
Rings,time for a rebuild....
Old Nov 25, 2003 | 05:01 AM
static_signal's Avatar
rings, valve seals, stop useing blue oil
Old Nov 25, 2003 | 05:20 AM
arw321's Avatar
Default Re: '98 Civic Type R - Blue Smoke (static_signal)
It's not your headgasket.
More than likely it's your rings. If it was a bad headgasket you'd be burning coolant, which would be white smoke.
Old Nov 25, 2003 | 06:49 AM
AMG's Avatar
AMG
Default Re: '98 Civic Type R - Blue Smoke (arw321)
Is it really a ctr?
Old Nov 25, 2003 | 08:06 AM
r2ck_p's Avatar
Default Re: '98 Civic Type R - Blue Smoke (dohcVTEChatch)
Thanks again guys!!! Will speak to Honda this weekend, I believe it is a long job to do, that means more money, arhhhh!!! Other then that i will stop using the blue oil, ha ha ha.
Yeah is a '98 CTR in black, there isn't many here in the UK, but if there is they are always White. I tell u what, wish I was over there want to see the drag racing etc....as there isn't much that happens here, I mean once every few months we have a drag racing event on an old airfield thats about it, the rest is street racing.
Thanks,
Rik
PnoyGS-R
Nov 1, 2010 12:45 PM
ck123
Mar 31, 2006 06:38 PM
Tegster
Jan 9, 2005 11:01 AM
Cyber ITR
Jan 7, 2002 05:10 PM
4drGSR
Jun 19, 2001 05:15 AM
