Transmission Mounting Bolts
Old Nov 23, 2003 | 09:53 PM
Muckman's Avatar
Moderator in Chief
Default Transmission Mounting Bolts
This is pissing me off. Ive been looking through the tranny section of my Helms for hours. I need to know how many bolts hold the tranny the the engine in a GSR. These are those big huge bolts that are called "Transmission Mounting Bolts" in the Helms. I dont need any smart *** answers like "count them" heh because the tranny and engine are 30 miles away from me at my engine builder and I would if I could. He says Im missing some and I need to know how many there should be. However of course the Helms could not just tell you. I would also like to know the size of these bolts too if possible. diamater x thread x length
1.) how many
2.) size
TIA!
Old Nov 24, 2003 | 05:08 AM
94lsboost's Avatar
Default Re: Transmission Mounting Bolts (Muckman)
off the top of my head...3 bell housing bolts on top front, starter 2 bolts on top rear. Bottom rear 3 b.h. bolts, like 5 more bolts alongthe flywheel shield.... think that's it.
Old Nov 24, 2003 | 05:50 AM
Muckman's Avatar
Moderator in Chief
Default Re: Transmission Mounting Bolts (94lsboost)
Thank you!
Do you know if they are all different sizes or uniform?
Old Nov 24, 2003 | 05:58 AM
94lsboost's Avatar
Well I believe there are 7 bell housing bolts the same size, the 2 from the starter are unique from all the rest, 2 that hold the shield on are smaller than allthe rest, 2 are short, but bigger in diameter. That is from my reccolection only....not definate. Hope it possibly helps.
Only the long skinny starter bolt acts as a "mounting' bolt for the tranny, the other simply holds the starter in place.
Old Nov 24, 2003 | 05:59 AM
eyesonlybob's Avatar
the only "mounting bolts" i remember are three in front of the starter and one behind it.
look at #8 on 13-5 in your helms...those are the only mounting bolts. the rest are for mounts. but i do not know the size.
Old Nov 24, 2003 | 06:18 AM
andrew dc's Avatar
Default Re: (eyesonlybob)
dont forget to remove the flywheel cover!
Old Nov 24, 2003 | 06:41 AM
jdmintegra1994's Avatar
Default Re: (andrew ef)
i'm going to the mechanic's right now to check on my car...i'll count the bolts and tell you when i get back.
Old Nov 25, 2003 | 06:42 AM
Muckman's Avatar
Moderator in Chief
Default Re: (jdmintegra1994)
You guys are great!
I can feel the love.
92lxsleeper
Apr 4, 2010 08:54 AM
civic_driver
25
Sep 28, 2005 10:52 AM
Ftrceo
Jun 14, 2005 03:36 PM
jcarothers
Jun 2, 2004 09:59 PM
thinkbrianthink
Apr 20, 2004 07:04 PM
