problem hooking up my Kendwood deck
Old Nov 23, 2003 | 12:18 PM
itsJDMyo's Avatar
Default problem hooking up my Kendwood deck
my friend gave me his Kendwood deck. and i know that the power wires are the "ACC" wire and the "POWER" wire. but when i connect all the right wires together. it doesn't work. it only works when i connect the "red" and "yellow" wire together from my deck to the "power" wire on the car. but when i do this, it doesn't save my memory on my deck when my car is off. what's wrong here...???????
Old Nov 23, 2003 | 12:33 PM
zanthrax's Avatar
the ACC (yellow wire) is used to run the radio.
the power (red wire) only powers the clock and the memory.
sounds to me like there is no power on the power wire, check your radiofuse.
if the fuse is OK, the easiest way to fix this is the run a new fused wires from your battery to your radio.
Modified by zanthrax at 12:53 PM 11/24/2003
Old Nov 23, 2003 | 08:51 PM
vigor5spd's Avatar
Default Re: problem hooking up my Kendwood deck (b00st)
You probably blew a fuse on the power wire.
Old Nov 24, 2003 | 04:33 AM
itsJDMyo's Avatar
Default Re: problem hooking up my Kendwood deck (vigor5spd)
but when i checked the fuse under the dashboard, it seemed fine
Old Nov 24, 2003 | 01:02 PM
zanthrax's Avatar
try testing for voltage at the HU.
a voltmeter would be easy. but you could also do it with 2 pieces of wire and a 12 testlamp.
Tyler Harteau
Oct 18, 2018 09:19 AM
MrBryan
May 28, 2007 04:27 AM
KrispyKreme
Audio / Security / Video
12
Mar 17, 2005 01:13 PM
Sirus
Oct 5, 2002 09:04 PM
OR-G
May 22, 2002 07:48 AM
