Is there a good way to clean rust out of the water jackets in a block?
Old Nov 22, 2003 | 07:43 PM
youngkow's Avatar
Default Is there a good way to clean rust out of the water jackets in a block?
I'm slowly trying to gather parts to build an engine, and I saw a block for sale that had rust in the water jackets. When I send the block out to get it sleeved, and they clean the block, would it be possible to get the rust removed? Thanks.
Old Nov 22, 2003 | 08:03 PM
Flamenco-T's Avatar
Default Re: Is there a good way to clean rust out of the water jackets in a block? (youngkow)
I doubt it's rust, it's propably oogle from the coolant. Just rinse it off or uses a hugh pressure rinse from local car wash and spray in along the water jacket.
YOu may want to take out the big 20mm bolt on the front of the block to the left of the oil dipstick to get all the rinsed water/coolant out..
stan
Old Nov 22, 2003 | 08:05 PM
youngkow's Avatar
Default Re: Is there a good way to clean rust out of the water jackets in a block? (jz)
on me. Why didn't I think of that? But I wonder what the orange coloration in the water jacket was. Hmmmmm..... anyways, guess I'm on my way to building an engine. Thanks!
Old Nov 22, 2003 | 08:07 PM
Flamenco-T's Avatar
when you get your block sleeves, they will cleaned it anyway. They will cut the stock sleeve and press in the aftermarket one and while doing that, they get all all the excess from the previous uses of it.
stan
Old Nov 22, 2003 | 08:38 PM
wHOAlly's Avatar
Default Re: Is there a good way to clean rust out of the water jackets in a block? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">20mm bolt on the front of the block to the left of the oil dipstick to get all the rinsed water/coolant out..</TD></TR></TABLE>
19mm
raverx3m
Jan 30, 2016 05:37 AM
hmt_eg
Feb 24, 2010 01:29 AM
integraboosted
Oct 13, 2007 09:20 PM
dpine
Jan 26, 2005 08:03 AM
Joon525
Feb 6, 2004 02:56 PM
