MSD DIG6 problems!!! Need help, very frustrated!
Old Nov 22, 2003 | 04:30 PM
NirVTEC's Avatar
Default MSD DIG6 problems!!! Need help, very frustrated!
The shop working on my car has tried 2 different MSDs and both make the car stutter at 5500. They've tried messing with the rev-limter and it doesn't help. W/o the MSD my car runs fine. I am using an MSD coil too. The techs at MSD have been no help I guess!...
Has anyone else had this problem? Its frustrating my shop as much as me.
Laughin2.2 said something about 2 wires not being able to be run near each other.....Does anyone know which 2 wires these are?
Thanks guys!
If we can't figure this thing out, what other options to I have to retard my timing? What does Jacobs make to do something like this? Crane? Mallory?
Old Nov 23, 2003 | 06:41 AM
NirVTEC's Avatar
Default Re: MSD DIG6 problems!!! Need help, very frustrated! (NirVTECn2o)
Anyone?!?!
Old Nov 23, 2003 | 07:33 AM
DANG YO's Avatar
i have the MSD dig6 adn i dont have any trouble with it, hope u figure it out tho...
Old Nov 23, 2003 | 06:22 PM
D-Man's Avatar
maybe you have a bad coil wire
Old Nov 24, 2003 | 07:57 AM
NirVTEC's Avatar
Default Re: MSD DIG6 problems!!! Need help, very frustrated! (D-Man)
Well, the car works fine w/o the MSD....But we will give that a try!
Old Nov 24, 2003 | 08:59 AM
D-Man's Avatar
yeah,the MSD puts alot of stress on that coil wire cause the problem to not show up running without it...its possible
Old Nov 24, 2003 | 09:13 AM
NirVTEC's Avatar
Going to try a new coil wire. Is there an upgraded one that can be used?
Problem begins at 5500 with or without VTEC. He set VTEC at 7000, and it still stuttered at 5500.
So maybe when it hits 5500, the MSD starts pushing some serious juice through it, and a bad coil wire would start to fail? Without the MSD, the "BAD" coil wire can handle the stock juice being put through it?!
Thanks for your help...............
****Still an open question!**** Need more input!
Modified by NirVTECn2o at 6:39 PM 11/24/2003
Old Nov 24, 2003 | 09:21 AM
D-Man's Avatar
most of the ones Ive seen you gotta cut and make one to length,like I use an Accel 8.8 wire for it.
Old Nov 24, 2003 | 09:39 AM
NirVTEC's Avatar
Is the coil wire the same type of wire as a plug wire? Would using a larger heavier duty wire do the trick???
Old Nov 24, 2003 | 10:42 AM
D-Man's Avatar
yes,its the same and any 8mm wire would do as long as its in good shape
Old Nov 24, 2003 | 11:23 AM
doublejz's Avatar
i agree with all, coil wire
Old Nov 24, 2003 | 11:33 AM
NirVTEC's Avatar
Default Re: MSD DIG6 problems!!! Need help, very frustrated! (doublejz)
Thanks everyone!!!
I will be sure to post the outcome. Should know in a couple hours!
Old Nov 24, 2003 | 01:35 PM
NirVTEC's Avatar
Any more input???
Old Nov 24, 2003 | 05:50 PM
NirVTEC's Avatar
Old Nov 24, 2003 | 07:35 PM
D-Man's Avatar
So I take it the coil wire wasnt the problem?
Old Nov 24, 2003 | 10:57 PM
Rtype16's Avatar
Are you positive you have all the settings right on the MSD. Also what are you using this for. I know to retard timing, but on what and why? Why don't you just sell it and buy a computer for the car which will reatrd the timing for you.
Old Nov 25, 2003 | 05:59 AM
NirVTEC's Avatar
Default Re: MSD DIG6 problems!!! Need help, very frustrated! (Rtype16)
Going to try the coil wire today.....
I don't feel like I am at the point of needing a computer right now. I am running it on an 80wet setup with all the bolt-ons and headwork.
All the settings have been checked several times as that was the most obvious of problems. The ground has been moved a couple times, and actually hooked right up to the battery.
BTW: What kind of computer would I get??? AEM EMS?
Old Dec 1, 2003 | 12:44 PM
NirVTEC's Avatar
Well.....new plugs/wires/coil wire and still having the same problems.
I need someones help with this. MSD has been no help at all either.
Any other input? I am ready to give up on the car until spring.
Can someone refer me to another site where I may be able to find help.
Old Dec 1, 2003 | 01:30 PM
D-Man's Avatar
damn,you still didnt fix it,must be driving you crazy....anyway,When you take off the msd do you also take remove the external coil and cap with coil connection and you put back stock cap and internal coil?
Old Dec 1, 2003 | 02:11 PM
NirVTEC's Avatar
No....just remove the MSD box and it runs fine
Very puzzling, and scary that no one else has ahd this problem
Old Dec 1, 2003 | 02:20 PM
D-Man's Avatar
When your looking at the box on the side that has all the adjustment ***** for the retards and 2-step.The switch all the way to the right for the cylinder adjustment,just above the red light,it has 0-4 cyl,1-6 cyl etc etc...You have that switch on 0?...put all those switches on 0 if theyre not already
Old Dec 1, 2003 | 02:31 PM
NirVTEC's Avatar
Tried messing with all those!
Old Dec 1, 2003 | 02:36 PM
D-Man's Avatar
so you have them all on 0...what about the msd to coil wire,you have the orange wire to the + side and the black to the - side?
Old Dec 1, 2003 | 02:43 PM
D-Man's Avatar
and the wires for the msd to distributor,,you have the msd red to the two distributor black/yellow stripe wires and the msd white to the one distributor white/blue stripe?
Old Dec 1, 2003 | 02:50 PM
NirVTEC's Avatar
Hmmmm.....need to check that!
Mr HYDE
Jan 7, 2006 01:33 PM
hondabill
Jul 22, 2004 06:09 AM
FastNFurious
Jun 19, 2003 05:30 PM
ludegirl1004
Apr 28, 2002 08:31 PM
batboy18
Aug 26, 2001 05:01 PM
