Car is still bogging out like crazy, B18C1 ....please help me!
Old Nov 21, 2003 | 11:43 AM
StreetwizeRacin2's Avatar
Default Car is still bogging out like crazy, B18C1 ....please help me!
Like the title says, the car has been bogging really bad. It always happens at 2500 RPM when just crusing at low speed, esp. in 1st and 2nd gear. I dont know what it is , the fuel pressure is fine, changed the pump and filter, plugs, oil, etc...everything is good to go. I dont know why it is bogging, the car hesitates and just sits there , backfires then goes. Ill check the timing on Monday but I dont think that is it. The car is a 94 CX with a 98 B18C1 swap.
Old Nov 21, 2003 | 11:45 AM
dantastic's Avatar
my guess is on the timing
Old Nov 21, 2003 | 11:54 AM
beastineg's Avatar
Default Re: Car is still bogging out like crazy, B18C1 ....please help me! (StreetwizeRacin2)
Sent you a IM
Good luck
Old Nov 21, 2003 | 03:34 PM
el bumpo
Old Nov 22, 2003 | 03:40 PM
anyone else have words of advice?
Old Nov 22, 2003 | 04:17 PM
BrynnTheSlut's Avatar
my car did the same thing! My car would occasionally throw code 10, which is the IAT sensor, try replacing that and see what happens.
Old Nov 22, 2003 | 04:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (BrynnTheSlut)
if it isnt the timming, check it for compression. may have a burned or bent valve if it is popping like that.
Old Nov 22, 2003 | 05:55 PM
DumpedSi's Avatar
Default Re: (boostedcivicsir)
I had the same problem.. My car would always bogged out around 3k rpms.. It was the o2 sensor
Old Nov 22, 2003 | 06:49 PM
G U E C O's Avatar
Modified by stock93cx at 11:04 AM 11/23/2003
Old Nov 22, 2003 | 08:32 PM
JDMlyfestyle's Avatar
Do u got a CEL. if so see what it flashes and if u need to identify the code i have a code list in my Sig.
Old Nov 23, 2003 | 06:46 AM
My CEL is not on though, can it still be throwing a code even if the CEL isnt on? Should I run a diagnostics test on it? The car doesnt only bog but it is SO much slower and barely moves at half throttle, this sucks :-(
Old Nov 23, 2003 | 01:23 PM
I also notice it misfires when driving in gear and apply pressure on the gas pedal aroudn 3000 RPM it misfires and wont go anywhere
Old Nov 23, 2003 | 01:33 PM
dantastic's Avatar
Default Re: (StreetwizeRacin2)
when u changed teh pump, u put a gsr pump in right? new or used? make sure its alright. also check to make sure ur cam timing is all right
Old Nov 23, 2003 | 04:10 PM
i changed it to a CTR pump. Regardless, it still had theses effects before and after the new pump... I also did a full tune up on the car a month ago. The car was running AWESOME and sooo fast and smooth when i bought it a month ago, then it started doing this nonsense.....
Old Nov 23, 2003 | 05:28 PM
blbvtec's Avatar
mine does the same thing. i describe it as more of a miss. like all the cylinders arent firing. i can floor it when this happens and nothing changes. it just sputters.
its so erratic though that i cant find out whats up. it could be months or days between its occurences
Old Nov 24, 2003 | 12:04 PM
Also, my car has a 6A MSD box, the guy who sold me the car said it is sorta old, and the problem might lay in the box...I might just take the box out, damn wires confuse me though
Old Mar 25, 2006 | 07:46 PM
9WON4's Avatar
Default Re: (G U E C O)
you really think so?........thanks bro!!!
Old Mar 25, 2006 | 09:17 PM
matt56's Avatar
here check out this thread. i just helped a guy with a very simular problem. heres the Link.
https://honda-tech.com/zerothread?id=1564104
Old Mar 26, 2006 | 06:07 AM
9WON4's Avatar
Default Re: (matt56)
thanks matt! ill check it now before i kill myself
Old Mar 26, 2006 | 06:17 AM
9WON4's Avatar
Default Re: (kidkanedtx)
matt this doesnt help me....my problem is different........:I havent touched the timing on my jdmb18c1. Rpm put in a new belt with pumps at swap time......the motor ran like a Gem for a full year.....Then recently, I took it to the track and we experienced some sputtering on the way(before we got there). I bought new plugs which are pre-gapped from acura(at the dealer-oem)......and when I pulled them....the plugs and bottom of the spark plug boots we're covered in oil. I did the required valve cover gasket(cause thats what that is-the grommets were there problems) repair. Motor seemed to run harder than ever for like 2 days until the sputtering AGAIN at 2000-3500 rpm's.............I was beside myself......I have changed the wires and the plugs twice(my 1st set got drenched in oil before I repaired the valve cover gasket set).........the dist. rotor and cap are soooo clean.....No Red dust .....just dust from packin' 30,000 miles on the motor. It stops bogging and sputtering after I floor it.......How do I stop this........it ran great for so long.....and the valve cover gasket was prolly never the MAIN problem all along!!! I had my racing mechanic/pal look at my car.....he diagnosed the distributor and wires to ensure they were getting a pulse he said they were and that it was most likely an ignition problem. I have received no codes......I only wish I did!!! Could this be an ECU Problem.........(should I get a usdm 0bd21 ecu or a jdm?) thanks for ANY help......Im really confused.
Old Mar 26, 2006 | 06:23 AM
9WON4's Avatar
by the way I am getting no CEL and the motor is bone stock with the exception of a racing flywheel/clutch
Old Mar 26, 2006 | 07:22 PM
littlegreenb18's Avatar
that is my post that matt posted, and actually it sounds exactly like my problem, i'm anxious to see what you come up with, i'm gonna check my vacume readings tomrrow or at least pretty soon
Old Apr 2, 2006 | 06:13 AM
9WON4's Avatar
Default Re: (littlegreenb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">that is my post that matt posted, and actually it sounds exactly like my problem, i'm anxious to see what you come up with, i'm gonna check my vacume readings tomrrow or at least pretty soon</TD></TR></TABLE>
yea man....im gonna change the o2 sensor 1st........tell what happs
Old Apr 2, 2006 | 06:49 AM
i'm thinking its the o2 sensor, cuz i've tried everything else i'm anxious to find out how it works out for you, i just want mine fixed
NinjaJDMB18c
Dec 2, 2013 04:42 AM
TerrenceDinesen
May 15, 2012 11:08 AM
itrintegra
Sep 24, 2007 07:31 PM
djtony5
Dec 8, 2005 09:51 AM
turbotegrar
May 20, 2004 04:13 AM
