Shift linkage problem...
Old Nov 21, 2003 | 06:06 AM
eghatchproject's Avatar
Default Shift linkage problem...
Last night I ran my LS swapped hatch at the track and on the way home I felt the linkage fall off the tranny. Since my friend was the one who hooked that up when we did the swap I didn't see what actually keeps it on the tranny. Do you guys know what broke off or what part I need to get to fix this? Thanks alot..
Old Nov 21, 2003 | 06:34 AM
Default Re: Shift linkage problem... (eghatchproject)
nobody knows what makes the shift linkage stay on the tranny?
Old Nov 21, 2003 | 07:15 AM
monicle's Avatar
it depends on which part came off the tranny. the shift linkage is 2 parts. its either going to be a bolt that came out or someone didnt put the spring pin back in (bitch pin)
Old Nov 21, 2003 | 07:23 AM
RCautoworks's Avatar
Default Re: Shift linkage problem... (monicle)
Some cars won't have #15, the torque rod will just bolt to the trans instead.
Old Nov 21, 2003 | 07:26 AM
esoterEK..'s Avatar
I hope he put in #22
Old Nov 21, 2003 | 07:39 AM
Default Re: Shift linkage problem... (90blackcrx)
holy ish monicle you rock! the bitch pin is in there and not going anywhere believe me i bashed it with a hammer. it looks like im missing one of those bolts either 27 or 28 i cant really tell without looking at under my car. thanks again guys
Old Nov 21, 2003 | 07:41 AM
EJ1 wilcox's Avatar
Default Re: (EGkwazhimoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkwazhimoto &raquo;</TD></TR><TR><TD CLASS="quote">I hope he put in #22</TD></TR></TABLE>
Yeah, I had a bolt in there for a while instead of the pin! There was so much play in my shifter!! It sucked!
#22 is definately a friend of mine. So small, yet makes suck a large difference!!!
Old Nov 21, 2003 | 08:31 AM
monicle's Avatar
no problem
Old Nov 21, 2003 | 10:59 AM
Default Re: (koreanwilcox)
i know exactly what you mean first and second gear used to be against the side of my front seat and fifth gear was WAY over to the right.
Old Nov 21, 2003 | 11:02 AM
SICKSOLSI's Avatar
Default Re: (eghatchproject)
#22 aka BITCH PIN
Old Nov 22, 2003 | 08:21 AM
anybody know what size #27 is from the diagram?
Old Nov 22, 2003 | 08:27 AM
EK MONEY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchproject &raquo;</TD></TR><TR><TD CLASS="quote">anybody know what size #27 is from the diagram?</TD></TR></TABLE>
12mm
Old Nov 22, 2003 | 08:28 AM
Default Re: Shift linkage problem... (Peagreenhatch)
thanks are the threads different or can i pick this up wherever? reason being acura parts is closed on the weekend
Dr.Fixit
Oct 22, 2013 12:42 AM
mmmbrapND
Transmission & Drivetrain
Apr 7, 2009 06:18 PM
preludedriva
16
Aug 8, 2007 03:48 PM
widecrx
Jun 24, 2007 11:50 AM
cincispeedemon
Oct 9, 2004 02:55 PM
