max psi non intercooled?
Old Nov 20, 2003 | 09:54 PM
goofball123321's Avatar
Default max psi non intercooled?
What's the max psi I could boost w/o an intercooler? I have a d16a6 w/ apexi turbo kit. thanks.
Old Nov 21, 2003 | 12:20 AM
bump
Old Nov 21, 2003 | 12:40 AM
beerbongskickass's Avatar
Default Re: (goofball123321)
I would just wait until you get an intercooler to boost.
Old Nov 21, 2003 | 03:54 AM
RedTegLS's Avatar
Default Re: (beerbongskickass)
A lot of people that dont want to spend a lot of money on an intercooler just get one of an eclipse or something else from a junkyard. Usually ~$100.
Old Nov 21, 2003 | 12:07 PM
Default Re: (RedTegLS)
https://honda-tech.com/zerothread?id=684467
These intercoolers are a little over $200 and will work well for you.
Old Nov 21, 2003 | 12:20 PM
EpDarks's Avatar
To answer the question.
4-5 PSI tops.
Old Nov 21, 2003 | 12:59 PM
psycho_civic's Avatar
my friend has been running non intercooled 6 pounds on his teg for about 6 months and everthing is great, he's getting one tho in about 3 weeks
Old Nov 21, 2003 | 04:55 PM
ok thanks for the info, i had a dsm smic but it dint work for me cause i dint have enough room behind the right side of the bumper. i guess i'll have to settle for a front mount on ebay or something.
Old Nov 21, 2003 | 05:20 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: max psi non intercooled? (goofball123321)
I would say 5-6 psi tops, and that's only if you have good engine management, your compression isn't too high, and the weather isn't really hot. You probably don't want to hear it again but intercooling is like getting *nearly* free power and reliability. I mean, you can boost without intercooling, but it's like playing baseball without wearing a cup. It's your choice, it's your *****...uh, I mean motor, but I think it's about the cheapest insurance you'll ever find. How about the IC out of a mkIII supra, probe, mr2? No need for the bling bling unless that's what you really want. Good luck.
Old Nov 21, 2003 | 06:18 PM
shermanyang's Avatar
Default Re: max psi non intercooled? (tjbizzo)
5 psi...and don't try uping it cause you'll just want more.
Old Nov 21, 2003 | 07:49 PM
Joseph Davis's Avatar
Default Re: max psi non intercooled? (shermanyang)
I ran 7 for close to a year on an LS, had one or two 9 psi glory runs.
The thing about non-IC is if the compressor is properly matched and all that physics ****, you make more power at lower boost than most ideal IC'd setups. I repeatedly raced an LS1 Z28 on 5 psi non-IC a couple times back to back, each time his rear bumper pulled to my front bumper on the launch and he pulled exactly one car on me by the time we hit 70 mph. If I hadn't had OverblownTeg's heavy 200lb **** *** in the CRX, might have been different.
I don't think having no IC is a bad thing, I just think you need to monitor intake charge temps to make sure you don't have a "bad" non-IC setup. Honda engines are fragile, and are more prone to detonating under high temps than many other engines. There is a whole camp of domestic owners who swear by non-IC turbo setups (on street cars) for several reasons - cost, complexity, being a street car and not a race car, and the fact that a badly chosen IC costs you power.
Old Nov 21, 2003 | 08:56 PM
mskibbz-T's Avatar
Default Re: max psi non intercooled? (J. Davis)
I always enjoy your posts J Davis... That agent icon is so utterly perfect at representing your persona
91glassycrx
May 7, 2004 12:26 PM
Arsenal
Oct 13, 2003 06:55 AM
RiceBurner98SC
Jan 9, 2003 10:17 PM
Duck Sauce
Nov 26, 2001 02:43 PM
prjctCIVIC
Jun 26, 2001 03:29 PM
