Cost of Turbo
Yo guys,
I gotta '97 GSR with 'bout 89k on it. Would a turbo add on be worht it?
Thinkin' i'll need a new motor before that.
How much will a turbo setup cost??
Parts, Labor?
Very curious.
Thanks guys!!
Parts, Labor?
Very curious.
Thanks guys!!
Sounds like a noob question. -=P Ask the force Induction forums.
Mind to ask, who are you? Im also from Albq, NM.
(oh yea, btw. Albuquerque is spelled wrong on your info there) -=P
I'm in Albuquerque too. Msg me on AIM and i'll tell you everything you need to know about turbo'ing a honda the right way.
Locally, Solid-Technology is a good place to check out to get information. They are doing a built motor and turbo on a civic si, and they also have a 5G prelude that they are putting together a kit for.
My aim is Ramocheese
A turbo kit can cost you $1,500-**** $5k, it all depend son what parts you get, your goals, your budget.
Theres no need to swap in a new motor, you have under 100k, no need to waste a perfectly running motor.
I bought a kit for $1900 and so far WITH OUT any labor I am over $3000. Hahahahaha. When I first got on here someone said dont try and boost with less than 4 grand and I laughed to myself......yeah......they were right! If I had it to do over I would buy the DRAG kit from ben @ importparts.com and he is giving a FREE Hondata! check the top of the forced induction forum!
i say the cost of turbo done right with at least pistons
and new parts (timingbelt water bump all gaskets and all the other good stuff)
at least 5,000
at least 5,000
Def. noob to the Teg.
Just got it a month ago.
First Honda I've owned.
Love it .
Need more power!!
And more money.
But just getting an idea.
Thanks guys.
Black '97 GSR.
Love it .
Need more power!!
And more money.
Thanks guys.
Black '97 GSR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 »</TD></TR><TR><TD CLASS="quote">a lot</TD></TR></TABLE>
Like definitely more than 5 bucks!!!
I've seen too many blown up turboed Hondas. Look into a built block and some kind of top end work. I've got a DOHC ZC Crx and I'm thinking about going with boost. My estimated build up sheet to do it the so called "right way" with a semi mild custom setup was around 7000. There's a lotta stuff some people take for granted when they plan to go turbo.....don't be one of them. Also if you're looking at a turbo kit be wary..... they don't always solve all problems either....Just my .02(Remember, Honda motors weren't built for boost....)
3-4k for a good kit, ( i am going with the full-race.com kit) , about 2k for sleeving, forged pistons and rods, and around 600-1k for engine management. (hondata, aem ems, etc.) This is the only way I would go turbo. I suppose you dont have to get forged internals and could run low boost, but eventually your rings/pistons will go, might as well get it out of the way, so you won't have any downtime later on down the road.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">http://www.cse.uconn.edu/~yele....html</TD></TR></TABLE>
Rofl I know too many people with WRX's here. You have to narrow it down. I am good friends with Nathan from TurboXS though. He used to live here before he got the job doing sales/dyno testing at TurboXS.
He was the fastest WRX in the country for a little while. He ran 12.3 about 5 months after the WRX came out in the USA.
boost it!
turbo kits run around $2000-$3500. labor will run you a good $500-$700 for install. then youll need a clutch... some guages... a bunch of little things to make your kit efficient. it gets costly, but it all depends on how you want to put it together.
Im sure lots can put together a fully biult reaced turbo, with the blocks built. Etc. o_O Have fun.
