OBD 0 distributor bearings
Old Nov 20, 2003 | 08:09 PM
Big Bang's Avatar
Default OBD 0 distributor bearings
ok my distributor sounds like it's about to blow itself up. Can i just replcae the bearings or do i need a whole new unit?
Old Nov 20, 2003 | 08:42 PM
Newman's Avatar
New User
Default Re: OBD 0 distributor bearings (The Converted)
You "can" replace it, but it's a PITA to do so. If you do replace them, use the guts from either a CRX or 90-91 Integra distributor, as it's the same thing and uses OBD-0 parts. If it's NOT a 1st gen B16A distributor, then just use that bad one as a core and get one from Kragen/Pepboys/Autozone/where ever and get a rebuilt one in new condition. If you do have a 1st gen B16A distributor, then you can't get another refurb'd one as they never made the OBD-0 DOHC VTEC distributor in the US.
Old Nov 21, 2003 | 10:03 AM
Big Bang's Avatar
Default Re: OBD 0 distributor bearings (Newman)
so is the only real difference the housing? can i put all the crx si guts in my b16a1 distributor?
Old Nov 23, 2003 | 01:49 PM
HighVelocity's Avatar
my speed shop high velocity rebuilds distributors. for a low price of 150 for info call 718-932-3060
Old Nov 24, 2003 | 07:46 AM
hondahans's Avatar
I've done this 10 times or so on my 90 Teg w/ b16. i was told it couldn't be done but i was curious to see why. I've found that the easiest way (assuming we're talking b16 VTEC distr.) is to find an Ls obd-0 integra (90-91) and swap EVERYTHING as a whole in to the vtec housing. everything is the exact same. and they're cheap at junk yards. some of the sensors may look a little different (sometimes), but thats due to diff. manufactrers. you will need a t-15 (i think it was t-15 just buy the bit set) TORX piece, as the factory didnt want us taking them apart. good luck pm me if u have any questions. and yes, automatic distr. will give the same results..... hans->
edit: the torx need to be the SECURITY type bits.....
jakscivic
Jun 2, 2006 11:08 AM
turtleb16a
Jul 3, 2002 12:48 PM
out2wincrx
Jun 9, 2002 07:41 PM
