need help identifying my motor
Old Nov 20, 2003 | 05:12 PM
kucherenko's Avatar
Default need help identifying my motor
i recently got a swap to my 99 civic ex.. the dood say its a jdm b18c5 but when i look at the block it just say b18c... so im thinking it could be a gs-r bottom end and si head and the tranny is lsd... what should i be looking for to see what it really is..i know i can take of the head to se if it bore inside but any other suggestion would be greatly aprriciated..
Old Nov 20, 2003 | 07:03 PM
ultimatehonda's Avatar
Default Re: need help identifying my motor (kucherenko)
The head would be a si or R if it has pr3 stamped into it...I think to check to see if you have lsd, you can jack up ur car and spin one wheel to see if the other one spins too...im not to sure on that or if that is the correct process....Im sure the jdm masta out there can help u out
Old Nov 20, 2003 | 07:11 PM
B2FiNiTY's Avatar
First of all JDM "GSR" and ITR motors have the stamp B18C.
Things to check for:
1) intake manifold/throttle body
2)valve cover
3)pr3-x
4)exhaust manifold
5)tranny gearing
6)96 vs 98 spec itr (few changes)
92TypeR's Avatar
FSAE
Default Re: need help identifying my motor (B2FiNiTY)
Green paint behind the distributor will solve all your worries.
Old Nov 20, 2003 | 09:16 PM
jdmspoonitr's Avatar
Default Re: need help identifying my motor (92TypeR)
Checking for lsd would be no good. They were optional on jdm sir-g.
em1_niokka
Mar 9, 2012 07:07 AM
Yonnie Tsunami
Mar 1, 2012 08:43 PM
Wo-Nelly
Nov 11, 2004 06:38 AM
blufke
18
Jun 15, 2002 06:38 PM
jdmciviceg
Mar 28, 2002 09:08 AM
