JDM b18c5 into EG
Old Nov 20, 2003 | 09:05 AM
lowboost civ2's Avatar
Default JDM b18c5 into EG
jdm r into cx, what ecu(s) can i use? what exactly needs to be done to the cx harness besides running the vtec solenoid and pressure swtch wires??
Old Nov 20, 2003 | 09:08 AM
slammed_93_hatch's Avatar
Default Re: JDM b18c5 into EG (lowboost civ2)
search dude all these questions are in here, but ill help you out with the ECu, you just need a ECU from a 5 speed vtec motor, i think. Im not sure if you have to use DOHC or if you can use sohc
Old Nov 20, 2003 | 09:16 AM
SikofFalln's Avatar
Default Re: JDM b18c5 into EG (slammed_93_hatch)
A chipped P28 would probally be the easiest ECU to get a hold of. Do a search, you will find all the info you need andthen some.
Good ol' Screwtape's Avatar
Multi-paradigm
BauleyCivic's Avatar
Risky Business
https://honda-tech.com/zerothread?id=595648
https://honda-tech.com/zerothread?id=600672
https://honda-tech.com/zerothread?id=569500
https://honda-tech.com/zerothread?id=106400
420eg
23
Aug 28, 2014 02:45 PM
DasaEJ1
Mar 9, 2005 07:46 PM
djsire
Aug 25, 2004 10:02 AM
darkmarc
Aug 20, 2004 09:45 AM
ELUD THS
Jun 18, 2003 09:34 AM
