n00b q about coolant
Old Nov 19, 2003 | 07:28 PM
AznJohn33's Avatar
Default n00b q about coolant
my car started running low on coolant...if i just bought some Schucks kind to keep me going temporarily, am I supposed to mix THAT with 50/50 water too? Or do I just pour it in straight?
And can someone how the radiator works wit the coolant reservoir?
I'm so lost
Old Nov 19, 2003 | 07:33 PM
timmy8151's Avatar
If you bought pre-mixed coolant then you wont have to mix. If you bought concentrated fluid then you should mix 50/50 with distilled water. Also, make sure you use the green coolant and not the orange GM stuff.
Old Nov 19, 2003 | 07:43 PM
acteg94's Avatar
Default Re: (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">If you bought pre-mixed coolant then you wont have to mix. If you bought concentrated fluid then you should mix 50/50 with distilled water. Also, make sure you use the green coolant and not the orange GM stuff.</TD></TR></TABLE>
plus, make sure when u measure the engine is cooled down, so you know exactly how much coolant you need to add ....
Old Nov 19, 2003 | 08:32 PM
B16OnTop's Avatar
Default Re: (acteg94)
why dont you just change your coolant? i changed mine and found hair, toenails, dirt, bugs, and grass in there, but i have no clue how that crap got in there
Old Nov 19, 2003 | 09:39 PM
SIK IN DA HED's Avatar
New User
Default Re: (B16OnTop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16OnTop &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just change your coolant? i changed mine and found hair, toenails, dirt, bugs, and grass in there, but i have no clue how that crap got in there </TD></TR></TABLE>
hair? wtf? hahah
dont use cheap collant brands unless you plan on flushing out your coolant system as soon as you get the chance to.
Old Nov 19, 2003 | 10:36 PM
AznJohn33's Avatar
Default Re: (SIK IN DA HED)
If I take it to a shop to have it all drained n flushed out, how much would it cost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIK IN DA HED &raquo;</TD></TR><TR><TD CLASS="quote">
hair? wtf? hahah
dont use cheap collant brands unless you plan on flushing out your coolant system as soon as you get the chance to.</TD></TR></TABLE>
Old Nov 19, 2003 | 10:38 PM
integraL's Avatar
Default Re: (AznJohn33)
when are we supposed to flush out coolant again? every oil change?
Old Nov 19, 2003 | 11:53 PM
Boges's Avatar
Default Re: (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">when are we supposed to flush out coolant again? every oil change?</TD></TR></TABLE>That's a little excessive...Unless you change your oil annually.
Old Nov 20, 2003 | 02:29 AM
The HamsterBall's Avatar
every year.
Old Nov 20, 2003 | 08:43 PM
integraL's Avatar
Default Re: (Boges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boges &raquo;</TD></TR><TR><TD CLASS="quote">That's a little excessive...Unless you change your oil annually.</TD></TR></TABLE>
heh ok. is that the same for tranny fluid and brake fluid?
Old Nov 20, 2003 | 10:50 PM
Boges's Avatar
I do tranny fluid about every 15 thousand miles and brake fluid when i change the pads. I'm sure plenty of people do it more often though.
stiffinEK
Mar 17, 2009 06:31 AM
1.8
Apr 6, 2005 06:18 PM
dman81
Mar 7, 2005 10:19 AM
tianporn
Feb 17, 2005 11:03 PM
MikeyDB7
Jan 21, 2004 11:04 PM
