T3/T04E 50 trim VS 54 Trim
Old Sep 12, 2001 | 03:12 PM
Purelude's Avatar
Default T3/T04E 50 trim VS 54 Trim
Majestic turbo told me that the 50 trim makes more hp than the 54 trim? i thought that the higher up you go in trims the more hp you make but w/ compromised spool up.
he said the 50 trim was a race wheel, and provided nice top end, but the 54 was smoother and didn't deliver as much up top.
what do you guys know about this?
Old Sep 12, 2001 | 03:44 PM
dustin's Avatar
Default Re: T3/T04E 50 trim VS 54 Trim (Purelude)
Hmm sounds contradictory to the way I understand it... but majestic turbo knows their stuff.
Dustin
Old Sep 12, 2001 | 11:35 PM
Purelude's Avatar
Default Re: T3/T04E 50 trim VS 54 Trim (dustin)
yea, exactly what i thought.....the higher the trim, the more hp you get.....(generally of course)
Old Sep 13, 2001 | 12:00 AM
98lude's Avatar
I think the 50 trim is a very irregular trim. from what i read, it seems to be able to flow more than the rest, and a higher efficiency area than the 54 and 57 trim. moreover, it is more "resistant" to surge. take a look and compare the map; when i called majestic, i actually told them I wanted to upgrade my turbo to .50. However, due to some twist of event, I ended up with a .57 with stage 3 .63a/r.
Robert from Majestic told me that .50 is a race trim as well... *shrug* oh well, I will post pictures when my turbo comes back in the next few days.
Old Sep 13, 2001 | 12:39 PM
SiRkid's Avatar
Default Re: T3/T04E 50 trim VS 54 Trim (98lude)
hmmmmmm....we should get some answers to this.
Old Sep 13, 2001 | 01:20 PM
Seraph0's Avatar
Default Re: T3/T04E 50 trim VS 54 Trim (SiRkid)
Here are *some* answers.
The .50 trim is the ONLY T04E wheel with a 3.00" major diam. The entire rest of the T04E line uses a 2.95" major diam. That accounts for it's difference from the rest of the line. It is the most efficient T04E at (what?) 78% or so?? Very nice spool pattern. Linear up to its max airflow potential. It is my favorite wheel. The .54 has a funky pattern. And I *think* it actually DOES make less airflow than the .50. The .57 only can make about 20 more hp than the .50. And it spool sup slower because the larger inducer diam. means it needs more RPM to "bite" the air.
spoolin turbo s
Oct 4, 2007 10:37 AM
the.hamburglar
Aug 17, 2007 04:21 AM
Tippyman
Feb 28, 2007 07:46 AM
Del_Slowest
Oct 26, 2004 11:57 PM
DA6righthand
May 28, 2004 11:20 PM
