Cars with stock 3 bar map sensors
Old Nov 19, 2003 | 05:29 AM
dominate9's Avatar
Default Cars with stock 3 bar map sensors
Which cars should I look for at the junkyard?
Old Dec 4, 2004 | 08:25 PM
gotboostedvr6's Avatar
Default Re: Cars with stock 3 bar map sensors (dominate9)
bump
Old Dec 4, 2004 | 08:33 PM
TheShodan's Avatar
Moderator
Just go to GM parts.com... Junkyards that carried those 3 bars were LS1 powered GM F-bodies. Its better to just buy here or go online. I've got one if you'd like I'm no longer using. Make sure the part number doesn't start w/ 466.. that is the 2 bar map
Old Dec 4, 2004 | 09:13 PM
Default Re: (TheShodan)
could i use the 2 bar i dont plan on more than 10 psi. im going to junk yard sat ,i was wondering if anyone knew what cars i should look for that have either 2bar or 3bar.
Old Dec 4, 2004 | 09:48 PM
boostedsol's Avatar
Default Re: (gotboostedvr6)
I think a cyclone might have one... not 100% sure though..
Old Dec 4, 2004 | 10:22 PM
InTeGrA B18b1's Avatar
Default Re: (boostedsol)
stock map is a two bar isnt it? stock map can read up to 12 psi or something right? well im using the stock one on my car.
Old Dec 5, 2004 | 03:41 AM
turbotypeR@SPEC's Avatar
25 Year Member
turbo trans am.you can go to the gm dealer and buy them for about $60
Old Dec 5, 2004 | 03:50 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol &raquo;</TD></TR><TR><TD CLASS="quote">I think a cyclone might have one... not 100% sure though..</TD></TR></TABLE>
i doubt you would find any of these in a junk yard
Old Dec 22, 2004 | 03:07 PM
JohnnieChimpo's Avatar
Default Re: (Boosted Chemist)
The Syclone doesn't have the 3 bar.
The only thing that has it is the Turbo V6 TransAm only made it one year.
You could check the Mazda Millenia with the Miller-Otto cycle engine. It ran hellish boost.
You need a boosted car that runs more than 14psi stock.
Old Dec 22, 2004 | 03:23 PM
USDM 4G VTEC's Avatar
ebay has the 3 BAR for $45
i just gone one
and the pigtail will run u something like $17-28 bucks depending where u get it
Old Dec 22, 2004 | 03:40 PM
boostedcivicsir's Avatar
Mr. Badwrench
grand national
turbo trans am
Old Dec 22, 2004 | 05:48 PM
mrbsponge's Avatar
the grand nation is NOT a 3 bar, it is a 2 bar and looks identical to the turbo trans AM, but it will not work if you are already scaled for a 3 bar such as in hondata or uberdata
Old Dec 22, 2004 | 06:25 PM
T-RO's Avatar
If you are only boosting 10psi you dont need one...
Old Dec 22, 2004 | 07:19 PM
mike1114's Avatar
Default Re: (T-RO)
89 trans am and firebirds, the 6 or 8 cyl's had 3 bars....
I bought mine from lightingmotorsports.com for like $60-70 shipped with pigtail and new pins.
Old Dec 22, 2004 | 10:45 PM
W O T's Avatar
Default Re: (mike1114)
what are pigtails?
Old Dec 22, 2004 | 11:11 PM
raene's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">If you are only boosting 10psi you dont need one...</TD></TR></TABLE>
The pigtail is the plug that connects to the sensor.
hondatm
Jan 19, 2007 05:31 PM
crix351c
Jan 25, 2006 10:35 AM
1 POINT 8
Jan 29, 2004 02:21 PM
rrei
Apr 21, 2003 09:57 PM
98civicEX
Feb 4, 2003 07:46 PM
