What size piping should I use for my charge pipes?
Old Nov 18, 2003 | 09:26 PM
jonnybravo's Avatar
Default What size piping should I use for my charge pipes?
I plan on using a t3/t04e on my stock GSR and plan on making close to 300hp at 9psi. Thanks.
Old Nov 18, 2003 | 10:12 PM
PrecisionH23a's Avatar
Default Re: What size piping should I use for my charge pipes? (jonnybravo)
2 1/4" should be just fine for 300whp. Personally I have put out over 400 with 2 1/4" but I will be upgrading to 2 1/2" next season.
Old Nov 18, 2003 | 10:47 PM
jonnybravo's Avatar
Default Re: What size piping should I use for my charge pipes? (GudeH23a)
Thanks. Anyone else wanna chime in? Also, how will spool characteristics change between the 2 sizes?
Old Nov 19, 2003 | 06:25 AM
quikB18B's Avatar
2.25 2.5 at biggest.
Im running 2.25 from turbo to inlet of FMIC, and then 2.5 from outlet to throttle body. This is a popular choice by most people.
When it comes to intercooler piping bigger isnt always better, to big of a piping will hurt spool.
Old Nov 19, 2003 | 07:08 AM
Johnyquest's Avatar
Default Re: What size piping should I use for my charge pipes? (quikB18B)
I run 2" and it works just fine. No difference from my friends car running 2.25 / 2.5 at the same boost levels. Nothing noticeable as far as lag or power. I just wouldn't go smaller than 2". I say an inch or so bigger than your turbo's outlet. My turbo outlet is like 1.5" ID if i can remember correctly.
Old Nov 19, 2003 | 11:17 AM
jonnybravo's Avatar
Default Re: What size piping should I use for my charge pipes? (Johnyquest)
So for the direction of flow(turbo->IC->throttle body), I should go from small to big or big to small?
Old Nov 19, 2003 | 11:49 AM
quikB18B's Avatar
go small to bigger, or you can keep it consistent. ANother thing to think about when figuring out piping size make sure you knwo what size your intercooler inlet/outlet sizes are. 1) because transition hoses are like $20 a piece,and 2) keep the flow consistent.
ExplicitSpeed
Apr 1, 2004 09:42 AM
DownBoyDown
Dec 2, 2003 06:12 PM
Sinner
Oct 13, 2003 11:30 AM
Screamer
Apr 9, 2003 11:07 AM
DIY_Racing
Dec 26, 2002 08:59 AM
