oil on spark plug?
Old Nov 18, 2003 | 04:09 PM
743power's Avatar
Default oil on spark plug?
Can oily spark plug threads be from bad spark plug gaskets, or more likely bad headgasket?
Old Nov 18, 2003 | 04:20 PM
vtekthis's Avatar
or leaking piston rings. maby you got too much blowby
Old Nov 18, 2003 | 04:40 PM
EX-T's Avatar
Default Re: (vtekthis)
or valve seals...
do a compression test...
if your numbers are low, put some oil in the combustion chambers and do the test again....
if the numbers are still low, it's your valve seals, if your numbers are higher then it's your rings...
you want it to be your valve seals though...good luck...
Old Nov 18, 2003 | 04:47 PM
743power's Avatar
Default Re: (DSeriesBKilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">or valve seals...
you want it to be your valve seals though...good luck...</TD></TR></TABLE>
Yea, I'm doing compression and leak down tests soon just for kicks. This motor will be coming out in the spring, so if it's rings or seals, they'll be replaced anyway. Thanks for the replies.
Old Nov 18, 2003 | 06:32 PM
b20bvtec'd's Avatar
Default Re: oil on spark plug? (743)
Could your valve cover be leaking on top of the plugs and when you take them out lookin like they are covered with oil. Just checkin.
Old Nov 18, 2003 | 10:28 PM
Stripped Honda's Avatar
99-0104
Default Re: oil on spark plug? (b20bvtec'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20bvtec'd &raquo;</TD></TR><TR><TD CLASS="quote">Could your valve cover be leaking on top of the plugs and when you take them out lookin like they are covered with oil. Just checkin. </TD></TR></TABLE>
i agree with him i bet it is the tube seals if it is on the threads then that is most likely the problem
Ci-v-iC
23
Oct 7, 2014 11:21 AM
HDX15
11
May 14, 2013 04:30 AM
nengx07
20
Feb 6, 2009 08:10 PM
firewalkerr
Sep 12, 2007 02:06 PM
bigwig
Sep 23, 2003 09:13 PM
