why is my b16 hesitating and missing
Old Nov 17, 2003 | 06:59 PM
typesguy's Avatar
Default why is my b16 hesitating and missing
my b16a1 is missing pretty bad in the higher rpm's. it start to miss around 6,000rpm's up to 8200rpm's. my car is runing a little lean when it hit's vtec would running cause it to hesitate or do u think i should replace my spark plugs,dizzy cap and rotor also could the fuel filter be a problem .plese help me!!!!
Old Nov 17, 2003 | 08:48 PM
Redline130's Avatar
Default Re: why is my b16 hesitating and missing (b16crx000)
Do a little maintaince like you mentioned and see if that helps the problem. Cap, rotor, plugs, fuel filter, and plug wires if they are old. The check engine light isn't on by chance is it?
Old Nov 17, 2003 | 09:27 PM
mmuller's Avatar
Mad Scientist
Default Re: why is my b16 hesitating and missing (Redline130)
check the coil too
Old Nov 17, 2003 | 10:01 PM
showtymers619's Avatar
* B A N N E D *
Default Re: why is my b16 hesitating and missing (mmuller)
sounds like a sparkplug went bad.. happend to me.. on my turbo GSR
Old Nov 18, 2003 | 12:57 PM
typesguy's Avatar
thanks guy's and no i don't have a cel by the way
Old Nov 18, 2003 | 06:12 PM
b20bvtec'd's Avatar
My motor had similiar problems due to being too lean. It would hesitate for a second and then be okay. If your not runningthe stock ecu, and you do not know how lean it is running I would go to the dyno small price to pay could cause serious damage.
Old Nov 30, 2003 | 06:01 PM
typesguy's Avatar
do anyone know if your 02 sensors are bad it would cause missing and does anyone know of a way i can check my distributor to see if it's bad because i reaed somewhere if i see red dust on the rotor the wheel bearings or sumthings gone bad
Old Nov 30, 2003 | 06:07 PM
99blackcivicSi's Avatar
Default Re: (b16crx000)
Do you have a fuel pressure guage? any kind of fuel management? how do you know it is running lean? is it pinging? checked plugs?
also a friendly warning take that Avatar off before you get a PM from a mod, people use this site at work and we don't need anyone getting in treble.
Old Nov 30, 2003 | 06:08 PM
Kendall's Avatar
Give the car a good tune up and see what happens.
Old Nov 30, 2003 | 07:28 PM
typesguy's Avatar
yes i have a fuel pressure gauge and a fuel pressure regulator the fuel is set to 32psi any higher and the car misses even more.
Old Nov 30, 2003 | 11:06 PM
Kwuaymaikrup's Avatar
Add some oil. my GS-R did the exact same thing. I then added oil and it was fine.
-Ryan
Old Dec 1, 2003 | 06:12 AM
rsbad454's Avatar
Default Re: (Kwuaymaikrup)
do a search on b16 hesitation........try swapping your c8 and c16 O2 pins on ECU connector.......mine quit hestating by doing this.
biglebowskicivic
38
Mar 17, 2021 12:38 PM
egGSR_hi
May 16, 2009 12:23 PM
99blackdc2
Oct 28, 2006 08:40 PM
Brent1
23
Dec 31, 2005 03:01 PM
crxh22project
May 30, 2005 12:01 AM
