How many quarts of coolant?
Old Nov 17, 2003 | 05:23 PM
TypeRuz's Avatar
Default How many total quarts of coolant needed for coolnat change? (lost manual)
i bought the premixed Acura coolant/H2O from the dealer the other day (i think it's called Type II), and was told the one bottle is enough....but something tells me it would take more. i forgot the amount on the bottle and it's not with me, but it looked like about 1 gallons worth.
anyways, thanks in advance!
Old Nov 17, 2003 | 05:26 PM
B2FiNiTY's Avatar
Default Re: How many total quarts of coolant needed for coolnat change? (TypeRuz)
Get 2 gallons of type 2.
Old Nov 17, 2003 | 06:37 PM
Tweakmeister's Avatar
since you're in Florida...
get one container of the premix, and a gallon of distilled water.
you'll have to "bled" the system anyway, and the extra water is good for batteries, etc...
Old Nov 17, 2003 | 09:50 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How many total quarts of coolant needed for coolnat change? (Tweakmeister)
Our local, knowledgeable dealer (Acura of Brookfield) strongly recommends against using water in the cooling system of the cars. Honda puts strong limits on the quality of the water that's used in the premix fluid, whereas local water quality varies. They've seen radiators and cooling systems destroyed from the use of local water instead of the Honda premix fluid.
Old Nov 17, 2003 | 11:04 PM
euclid's Avatar
Default Re: How many total quarts of coolant needed for coolnat change? (nsxtasy)
the water needs to be distilled, otherwise the minerals will clog and erode the block. honda just premixes distilled water and radiator fluid 50/50.
Old Nov 17, 2003 | 11:51 PM
HYREV2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Our local, knowledgeable dealer (Acura of Brookfield) strongly recommends against using water in the cooling system of the cars. Honda puts strong limits on the quality of the water that's used in the premix fluid, whereas local water quality varies. They've seen radiators and cooling systems destroyed from the use of local water instead of the Honda premix fluid.
</TD></TR></TABLE> What about distilled water or filtered water?
Old Nov 18, 2003 | 07:23 AM
Old Nov 18, 2003 | 07:46 AM
jdmspoonitr's Avatar
Filtered water = bad
Tap water =
Old Nov 18, 2003 | 11:41 AM
Seedc2's Avatar
Default Re: How many total quarts of coolant needed for coolnat change? (jdmspoonitr)
so the radiator accepts a total of 1 gallon? 50 (half gallon) coolant / 50 (half gallon) distilled water?
Modified by kendogg at 1:20 PM 11/18/2003
Old Nov 18, 2003 | 11:57 AM
Default Re: How many total quarts of coolant needed for coolnat change? (kendogg)
2 gallons in the coolant system
1 gallon distilled water, 1 gallon coolant.
But if you buy Type-2 from Honda it comes 50/50 premixed so you need two gallon jugs of the Type-2
Old Nov 18, 2003 | 12:16 PM
.RJ's Avatar
.RJ
who uses coolant?
distilled water + water wetter
Old Nov 18, 2003 | 07:44 PM
Default Re: How many total quarts of coolant needed for coolnat change? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">who uses coolant?
distilled water + water wetter </TD></TR></TABLE>
try that this winter
I run like 15% coolant...
Old Nov 19, 2003 | 07:57 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">
distilled water. </TD></TR></TABLE>
E.K
Honda City
Oct 17, 2017 10:53 PM
tommyhondacar
Nov 22, 2010 10:27 PM
99bb6
10
Sep 23, 2004 08:36 PM
morepoop4u
Dec 16, 2001 03:39 PM
