Plug in Vtec head that is used for ls/vtec question.
Old Nov 17, 2003 | 04:27 PM
Trooper's Avatar
Default Plug in Vtec head that is used for ls/vtec question.
Hey guys i am hooking up my gages ( oil pres and temp ) and was wondering if there is pressure behind the plug that is used for ls vtec ( obverses a vtec head and block ) also ware would you recommend getting oil tembature from ? I was thinking that there needs to be a flow across or around the temp. probe to get a accurate reading?
Old Nov 17, 2003 | 07:25 PM
b19coupe's Avatar
Default Re: Plug in Vtec head that is used for ls/vtec question. (Trooper)
There is oil pressure behind the plug used for LS/VTEC on VTEC block/head engines. GSR block/head for example.
thugsbryan
Engine Machining & Assembly
Sep 17, 2015 05:00 PM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
SLow-Side
Nov 21, 2004 03:14 PM
99B16Si
Nov 22, 2003 03:54 PM
tegmaniac
Apr 24, 2003 07:37 PM
