some sohc vtec ?s, d16, please help!!!!!!!
Old Nov 17, 2003 | 02:25 PM
b18lsHaTcHBaCk's Avatar
Default some sohc vtec ?s, d16, please help!!!!!!!
heres the deal, im buying an engine from my friend for 200. its a d16 sohc vtec, its out of a 98 civic coupe and has 30,000 miles on it. He is selling to me for so cheap becase his dad got it from the dealership he works for, free. anyways, i want to know what kind of mods i would have to make to put this engine into an eg hatch. also id like to know how much one of these motors is worth. i gotta make a decision tonite so all your help is needed!
Thanks, Derek
Old Nov 17, 2003 | 02:30 PM
spyder's Avatar
New User
Default Re: some sohc vtec ?s, d16, please help!!!!!!! (b18lsHaTcHBaCk)
as far as positioning, it's a direct bolt-in. however, you need to know whether it needs an OBDI or OBDII ECU
Old Nov 17, 2003 | 02:34 PM
piscorpio's Avatar
Default Re: some sohc vtec ?s, d16, please help!!!!!!! (spyder)
Assuming it came stock in the 98 Civic it came out of, it would need OBDII. As far as the value of one, it varies. They can be had for a bargain if someone is just getting rid of it, but a complete swap rarely costs more than 800 dollars.
Old Nov 17, 2003 | 02:37 PM
spyder's Avatar
New User
Default Re: some sohc vtec ?s, d16, please help!!!!!!! (piscorpio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piscorpio &raquo;</TD></TR><TR><TD CLASS="quote">Assuming it came stock in the 98 Civic it came out of, it would need OBDII. As far as the value of one, it varies. They can be had for a bargain if someone is just getting rid of it, but a complete swap rarely costs more than 800 dollars.</TD></TR></TABLE>
piscorpio, you wouldn't happen to have a good source for d16 swaps at that price would you? My engine just got trashed...
Old Nov 17, 2003 | 02:38 PM
civicboisi's Avatar
Dunno...but 200 bucks for a SOHC VTEC motor w/30,000 miles is not bad at all...I'd pick it up. Also, i believe it's a direct bolt on and all you'd need is your VTEC wired...unless you have an SI or VX...someone correct me if i'm wrong
Old Nov 17, 2003 | 02:56 PM
nah its a cx, i have the harness out of an lx though, what kind of wiring mods do i have to do, other than get an obd2 ecu.
Old Nov 18, 2003 | 08:38 AM
piscorpio's Avatar
Sorry, I do not. Most of my shopping consisted of bargain hunting the honda-tech classifieds. You can also try thepartstrader.com, but may want to find someone local to you, as I have heard of quite a few bad transactions/scams go down on there. You can also check with local shops. There may be someone swapping in a B series who needs to unload their old d16, I had a couple of opportunities pop up this way, and its sort of how I ended up getting my transmission. You can also try some online engine dealers, hondamotorsonline.com seems to have a good reputation, but I am not sure they would carry d16's.
My little bit of experience tells me that you will likely pay more for the swap if buying from a shop or engine dealer, than you would buying from a private party looking to clear junk out of his garage. Good luck in your search.
Old Nov 18, 2003 | 08:42 AM
piscorpio's Avatar
Default Re: some sohc vtec ?s, d16, please help!!!!!!! (civicboisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi &raquo;</TD></TR><TR><TD CLASS="quote">but 200 bucks for a SOHC VTEC motor w/30,000 miles is not bad at all...I'd pick it up. Also, i believe it's a direct bolt on and all you'd need is your VTEC wired...unless you have an SI or VX...someone correct me if i'm wrong</TD></TR></TABLE>
I agree, assuming the engine is in good shape, 200 dollars is a good deal, even if it does not include transmission and ecu. And yes, it should be a pretty straightforward swap, no cutting or welding or special mounts involved.
Old Nov 18, 2003 | 12:49 PM
im more concerned about what kinda wiring im going to have to do, what sort of wiring does a swap like that involve to hook up vtec???
Old Nov 18, 2003 | 12:56 PM
ej1civic's Avatar
If you're putting it in an EG, you're gonna want to go with an obd1 ecu.
tigueremalo
Aug 5, 2006 08:40 AM
Nicaraguense13
11
May 12, 2006 09:49 AM
bostoncal
Nov 18, 2005 12:59 PM
cameronvickrey
May 9, 2005 05:27 PM
Tx92AccordExD
25
Jan 29, 2004 09:54 AM
