VTEC pressure valve????
Old Nov 17, 2003 | 09:24 AM
1ntensiveVTECivic's Avatar
Default HELP-----VTEC pressure valve????
heres the deal my brothers VTEC will not engage at all, this all coming after switching to K-series oil filter and we went to autozone and got the code -po 1 22-
some said its the VTEC pressure valve and my local shop said its the TPS.........
Old Nov 17, 2003 | 09:45 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: HELP-----VTEC pressure valve???? (1ntensiveVTECivic)
what kind of car are is this...and are u getting any codes?
Old Nov 17, 2003 | 09:49 AM
00 si......yes code 22
Old Nov 17, 2003 | 12:51 PM
Quiks66's Avatar
Default Re: (1ntensiveVTECivic)
That's your Vtec oil pressure sensor going out. I had the same problem with my B16 head. You have two options:
1. Replace the sensor (if you're sure it's not working anymore.
2. Just ground out the oil pressure sensor wire. I did this my CEL code for it went away. It's easy and free, but just make sure you always have enough oil in your motor.
obuhmyuh
Feb 26, 2008 10:07 AM
obuhmyuh
Feb 24, 2008 08:20 PM
itz_nij
Aug 9, 2006 03:02 PM
BobGnarly
May 23, 2004 05:28 PM
1ntensiveVTECivic
Nov 17, 2003 09:43 AM
