92 vx vtec-e problems... common?...solutions?
Old Nov 17, 2003 | 09:21 AM
EGhatched's Avatar
Default 92 vx vtec-e problems... common?...solutions?
I was wondering if anyone knows of or has had problems with their vtec-e in their car. The problem I am having is, it seems where the vtec crossover is (2500 rpm'ish) is that where vtec-e engages? It seems that I have a power loss and the engine boggs and sputters. I posted earlier about this problem but I still cant solve it. Its really starting to **** me off, its just so annoying. Like i said it my prevous post, when I unplug the vtec solenoid i throw a code but the motor doesnt show the symptoms. Is the solenoid bad? OR.... what else is associated with that solenoid or vtec-e in general that I can check?
here was my first post
https://honda-tech.com/zerothread?id=673988
thanks
Old Nov 17, 2003 | 09:31 AM
Jokerluv's Avatar
Default Re: 92 vx vtec-e problems... common?...solutions? (redcivicex2424)
crossover is 4200
Old Nov 17, 2003 | 09:54 AM
BatuKing's Avatar
I have a stock VX and that sound just like normal.
Old Nov 17, 2003 | 10:36 AM
EGhatched's Avatar
Default Re: 92 vx vtec-e problems... common?...solutions? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock VX and that sound just like normal.</TD></TR></TABLE>
I dont understand how this can be normal
Old Nov 17, 2003 | 10:12 PM
b18c1civic95's Avatar
the sad thing is, your probably getting better gas mileage still then most on here...No CELS huh !!? any new mods lately?? replaced any vacumm lines?? Leaking oil??
Old Nov 17, 2003 | 11:27 PM
FcUK It.'s Avatar
had the same problem, i have a 93 vx. changed my spark plugs and it didn't hesitate anymore
Old Nov 18, 2003 | 06:08 AM
EGhatched's Avatar
Default Re: 92 vx vtec-e problems... common?...solutions? (b18c1civic95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1civic95 &raquo;</TD></TR><TR><TD CLASS="quote">the sad thing is, your probably getting better gas mileage still then most on here...No CELS huh !!? any new mods lately?? replaced any vacumm lines?? Leaking oil??</TD></TR></TABLE>
I have not replaced any vacuum lines and it doesnt leak oil... this is what i've replaced so far and it has not solved the problem:
Plugs
Rotor
Cap
Ignition coil
Fuel Filter
i have no clue any more
Old Nov 19, 2003 | 08:04 PM
the coil isn't external is it??
Old Nov 19, 2003 | 09:29 PM
EGhatched's Avatar
yeah, the coil is an internal coil, inside the distributor
agordon
Nov 24, 2005 10:58 PM
streetracerjoey210
Feb 24, 2005 06:35 AM
92eg'n
Nov 17, 2004 05:14 PM
.ShawnD.
15
Sep 2, 2004 05:33 PM
FASTEG
Mar 20, 2003 07:36 AM
