D16Y8 T-Belt or Swap?
Old Nov 15, 2003 | 07:39 AM
uranazo's Avatar
Default D16Y8 T-Belt or Swap?
Hey, i got a 98 civic ex(EK D16Y8) and i got 80k on the car and its 5 years old so within the next 6 months to a year(i drive a lot) im gonna need a T-belt
I was thinking, for all the time and money invested into doing a T-Belt i might as well just do a swap... not sure if me n my friends are gonna do the swap/t-belt but also take into consideration if i decide to pay someone...
Feel free to add engines to swap to if youd like
Old Nov 15, 2003 | 07:44 AM
KiDSoL's Avatar
Default Re: D16Y8 T-Belt or Swap? (uranazo)
It like 200-300 to change a timitng belt most places, if you get a motor swap who's to say that timing belt is good on the next motor, plus labor for a swap usually runs liek 2-300 and the motor would be like 5-600 if your wanting a low milage engine. Maybe im wrong i dunno but thats how it went for me when i ruined my crank.
Old Nov 15, 2003 | 07:47 AM
ATS*Mark's Avatar
OG triple OG
man that has to be the dumbist thing ive ever herd , your gonna have to replace the timing belt on the swap too!!!!! a timing belt install at a garage will cost you around 400 , i think thats what honda charges . a swap will cost you at the cheapist 2500 - 3000 . you dont know about that motor your putting in your car , it could have been beatin to **** and your gonna trust the timing belt on it???? no no no . i know your a new user and all . but the timing belt to me is the most important part of the engine , when it goes , your motor goes......
Old Nov 15, 2003 | 07:57 AM
uranazo's Avatar
ya i know but if i did a swap the motor would come with 35k-40k on it or atleast thats what ive seen advertised so i wouldnt have to do a tbelt for a while, plus i could build the engine up a bit before i put it in... and since im not so knowledgeable bout this stuff i could learn quite a bit by taking apart and rebuiling the engine since it wouldnt be a problem if it wasnt working for a couple days bc i wouldnt have to drive it...
Old Nov 15, 2003 | 02:05 PM
91civicEX's Avatar
Default Re: (uranazo)
Keep my engine & do T-Belt and TURBO IT!!
YEA
Old Nov 15, 2003 | 02:08 PM
KiDSoL's Avatar
Honda recommend you change timing belt after 60 months due to aging or 60-90K depending on how the car is drivin. You Dont know how old a wherehouse motor is, and all swaps recommend you replacing the water pump, timing belt and pulley belts, regardless of the milage.
Old Nov 15, 2003 | 04:18 PM
BauleyCivic's Avatar
Risky Business
Default Re: (KiDSoL)
A timing belt is 30 dollars...why the hell would you pay anyone hundreds of dollars to install it?
https://honda-tech.com/zerothread?id=649277
Read that and be done with it!
Old Nov 15, 2003 | 04:24 PM
99blackcivicSi's Avatar
Default Re: (BauleyCivic)
keep the motor do the T belt (it isn't that hard!) and then turbo it thats my suggestion BOOST=FUN!!!!!
Dot3
Aug 21, 2018 03:58 PM
chevynova350
Jul 15, 2016 01:47 AM
Dr_EluSivE
Aug 1, 2003 08:53 AM
