Valve adjustments & nitrous questions h22
Old Nov 14, 2003 | 11:03 PM
LudeHatchH22a's Avatar
Default Valve adjustments & nitrous questions h22
Yeah, wel first of al i have skunk 2 valvesprings and cams, and my valves are starting to tap slightly, and i was wondering how to adjust the valve lash on the h22. Anyone know the specs of the top of your head?
also i have a NOS foger system and i was wondering, im planing on a 50 shot and i dont want to hook the fuel up to the injectors so it just shoots n2o, ill just slightly enrichin the rpms it wil be used in. i can do this right?
any sugestions on where on the manifold to atach the spider fo the nozzles?
thanks
Old Nov 15, 2003 | 07:34 AM
Default Re: Valve adjustments & nitrous questions h22 (LudeHatchH22a)
anyone?
Old Nov 15, 2003 | 07:49 AM
laughinxxx's Avatar
New User
Let me get this straight. You want to spray run nitrous by spraying nitrous through the intake and then tuning your car to run rich in the rpms that it will be used in. In order to compensate for the nitrous you'd have to run around a 9:1 a/f off of the bottle. The car won't even run on that and will foul plugs daily. Why don't you just put the kit in like it is supposed to be installed?
Old Nov 15, 2003 | 07:52 AM
Default Re: Valve adjustments & nitrous questions h22 (laughinxxx)
because the kit was used and im know i didnt get all the parts i need, but i mean is it that stupid? then why can people spray nitrous right into their intakes?
its not like i want to run a big shot.
Old Nov 15, 2003 | 08:53 AM
laughinxxx's Avatar
New User
People can spray nitrous into their intakes because:
1. They are spraying fuel along with the nitrous(ie wet kit)
2. They are running a dry kit, which uses vaccum from the nitrous flow to trick the fpr into adding more fuel.
You will blow your motor or make shitty NA power if you try to do what you are saying. In my opinion both are stupid.
Old Nov 15, 2003 | 09:09 AM
LudeyKrus's Avatar
You can run a small shot by simply richening up your a/f throughout the rpm's, but the max you can go is about a 30 shot.....search for a Sneaky Pete nitrous setup....
....But yeah, that is a stupid way of running nitrous. Just go buy the parts you're missing. The best and easiest way is to just plug up the fuel to the kit like it's supposed to; otherwise, you're asking for a blown motor.
Old Nov 15, 2003 | 10:50 AM
fastludeh22's Avatar
Default Re: Valve adjustments & nitrous questions h22 (LudeyKrus)
to tell the truth, BUT I DONT SUGGEST THIS, you can run 50 shot dry, w/just pulling the vacume line on the fpr.
i did it for awhile, when i didnt know much. i just thought the o2 sensor would make up for it, maybe it helps a little but not enough.
how ever i did go though about 5-6 bottles and it never blew
Old Nov 15, 2003 | 09:48 PM
Default Re: Valve adjustments & nitrous questions h22 (fastludeh22)
ill just use the whole system. it just sucks this is a used kit and i m missing a few important components
ah well, any ideas on the valve lash?
Old Nov 15, 2003 | 10:04 PM
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeHatchH22a &raquo;</TD></TR><TR><TD CLASS="quote">ill just use the whole system. it just sucks this is a used kit and i m missing a few important components
ah well, any ideas on the valve lash?</TD></TR></TABLE>
Its always good to run a naws system, with a few imortant missing components
Old Nov 15, 2003 | 10:17 PM
i know right, know where i can buy individual parts and fittings?
Old Nov 16, 2003 | 11:28 AM
laughinxxx's Avatar
New User
Default Re: (LudeHatchH22a)
summitracing.com or your local speed shop.
Old Nov 16, 2003 | 03:54 PM
NXLude's Avatar
your valves are tapping because of the springs...you will never get it to stop....Id junk them because they are very possible screwing up you head....or rocker arms at least.......
projectef
May 27, 2007 11:52 AM
93HONDAACCLUDE
Mar 15, 2005 02:16 PM
DarkBB4
Oct 29, 2004 09:17 PM
Ddogz15
Apr 25, 2004 11:47 AM
AllMotorITR
Jul 22, 2001 08:36 PM
