SPORT SHIFT, shifting hard and late
Old Nov 14, 2003 | 06:18 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default SPORT SHIFT, shifting hard and late
Has anyone experienced this with their 5th gen sprt shift Lude? It's odd but in the mornings when the engine and trans are cold shifting from first to 2nd gear hits soooooooo hard (almost like slamming gears on a manual trans), but when the car warms up it goes away.
If anyone has encountered this situation how did you aleviate the problem????
Old Nov 14, 2003 | 06:34 PM
bad-monkey's Avatar
Default Re: SPORT SHIFT, shifting hard and late (MUTANT X)
how many miles on your car?
could be a sign that it's about to fall apart and die on you.
with that POS tranny i wouldn't be surprised.
Old Nov 14, 2003 | 06:43 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: SPORT SHIFT, shifting hard and late (bad-monkey)
got 70k
with regular dealer maintenance
Old Nov 14, 2003 | 06:45 PM
na foo its john's Avatar
Sounds just like what my car did before the tranny died. I had 35k miles on my SS before the tranny died. Warrenty gave me a brand new one
Old Nov 14, 2003 | 06:59 PM
naujcdl's Avatar
Default Re: SPORT SHIFT, shifting hard and late (na foo its john)
well, with less than 52k mine went down the drain, so i got a 12 month warranty remanufactured tranny, which is ok, but i would highly recommend all you guys, to start buying part by part for a 5 speed manual swap (im in the process, auto tranny sucks *****)..
good luck with the sport suckmyballs shift tranny.
Old Nov 14, 2003 | 08:19 PM
BoM's Avatar
BoM
Default Re: SPORT SHIFT, shifting hard and late (naujcdl)
i have the same issue. here's what i usually do. don't put it in d4 (drive regular mode) when the ccar is cold. drive it with SS mode and use "quick" shifts and try to smooth the shift with throttle. and when coming to a stop, don't "downshift" just let the computer do the automatic down shift. as the car warms up, it'll stop and you can drive on D4
Old Nov 14, 2003 | 09:18 PM
bad-monkey's Avatar
yeah baby that thing while you save money for a 5spd swap.
Old Nov 14, 2003 | 10:10 PM
Jim Truett's Avatar
Default Re: (bad-monkey)
I refused to do anything to repair or replace the SS trans in my girlfriend's '99 lude. It is a 5 speed now. Read here: http://hpoa.org/forumdisplay.php?f=11
Old Nov 15, 2003 | 05:56 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: (Jim Truett)
Thanks for the replys , Im gonna try to have the whole trans flushed and filter changed . then i will have the fluids replaced with AMSOIL which i heard cleans and smoothens hard shifting auto trans.
6KAOS6
May 4, 2011 11:38 PM
tukiwawa
Nov 18, 2004 06:35 AM
MasterSaif
Apr 28, 2004 03:44 AM
invboost
11
Apr 2, 2004 06:08 PM
mrwink
Mar 4, 2004 07:42 PM
