funny THUD noise when driving.. could it be this...
Old Nov 14, 2003 | 02:00 PM
tyflip2's Avatar
Default funny THUD noise when driving.. could it be this...
when i am driving at a normal speed the car is fine but hwne i press the pedal further down the car begins to make a thud noise and kinda shake a little. i think it has somehting to do with the axles or something but not sure. it started on a long trip on the freeway. i also noticed a noise when turning left so could it be that there is not enough grease in the CV boots? what do you think
Old Nov 14, 2003 | 02:03 PM
92civicsi's Avatar
Default Re: funny THUD noise when driving.. could it be this... (tyflip2)
i have the same problem. when i accelerate and brake i get a thud noise on the driver side front. also when turning every now and then.
Old Nov 14, 2003 | 03:49 PM
uranazo's Avatar
well a repetitive thunking noise when braking would be warped rotars but when accelerating i dunno, maybe tranny prob or sounds like maybe your cv isnt quite connected all the way, check your boots...
Old Nov 14, 2003 | 05:38 PM
92civicsi's Avatar
Default Re: (uranazo)
i got a ripped tie rod boot.
Old Nov 14, 2003 | 05:45 PM
eyeamvic's Avatar
Default Re: (92civicsi)
Look to see if your cv joint boot is torn. Probably a bad cv joint. Time to get it replaced, not fun, I had to do it not too long ago.
Old Nov 14, 2003 | 06:59 PM
tyflip2's Avatar
Default Re: (eyeamvic)
that could be it. i had the same problem that it does it when i am braking and only sometimes when im turning. but it only does it sometimes. i dont know, ill check. thanks for the help
Old Nov 16, 2003 | 04:32 PM
crzyfool24's Avatar
Sounds like its your axle. It could be your driver side if you turn left and you can hear it. I had the same problem. When I push the gas it makes a thumbing noise and when I turn left it made it too. I replaced the axle and now its fine.
Old Nov 16, 2003 | 04:34 PM
crzyfool24's Avatar
Forgot to add somethin....It also does it when I brake. So just replace the driver side axle.
Old Nov 16, 2003 | 05:54 PM
tyflip2's Avatar
Default Re: (crzyfool24)
alright that should be it i hope. thanks alot for the help
Old Nov 16, 2003 | 05:57 PM
sohc it to me's Avatar
Default Re: (tyflip2)
i had the same problem as crazyfool and i did the same thing no problems
Old Nov 16, 2003 | 07:13 PM
blackeg's Avatar
Default Re: (95blkgsr)
its probably the cv joint. i recently broke a cv joint so bad that the boot ripped and 2 bearings fell out on the ground. when i drove it home (didnt know exactly how bad it was) it thumped and shook under acceleration. when i went to change the axle, half of it came off in my hand and the other half was still in the tranny- separated at the ripped cv joint. if your cv is bad just replace the whole axle, its not that hard should take about 2 hours if u never did it b4 and like 45 min if u know whats goin on.
Old Nov 22, 2003 | 12:40 AM
crzyfool24's Avatar
tyflip2...Did you ever replace your axle?
Old Nov 22, 2003 | 07:42 AM
tyflip2's Avatar
actually i am buying some new ones from someone on this board. and last night it got realllly bad and started doing it really loud when i accelerate. so i am gonna have to do that soon
picthis1
Dec 17, 2017 07:54 PM
Leexx
Aug 11, 2006 12:46 AM
remo
Mar 28, 2005 12:51 PM
superpirate25
Feb 18, 2004 02:50 PM
ghettols
14
Aug 15, 2003 12:52 PM
